Page 1 of 3 123 LastLast
Results 1 to 20 of 49
Thread: Hello and help from New Jersey confused
    May 2014
    Old Bridge New Jersey
    29
    NJ Mike: I deleted the other Thread you had on this subject since this one had more responses.
    --BoDarville, TFP Moderator
    Hello and thank you in advance ,opened pool last week took sample to pool guy was told FC was zero added 20 lbs of shock to date fc still read zero found this forum and purchased a TF-100 test kit here are the readings
    FC 6
    CC 1.5
    TC 7.5
    CH 300
    TA 130
    CYA 100
    I always went by what the pool guy said so all this is new to me what are my next steps also have a chlorinator with tablets installed .water is clear Thanks again Mike
    16 x30 grecian 15k,IG vinyl,jacuzzi sand filter model#DV 7-POS ,1.5 HP, Aqua Geni skimmer/feeder
    30,421
    Re: Hello and help from New Jersey confused
    Hey, Mike,
    Welcome to the forum.
    Your CYA is too high....almost surely from the over use of pucks. I would suggest you do two consective drain/refills....each at 33% of your pool water.
    That should get your CYA down around 40 or so and will make your season with your pool much more manageable and enjoyable.
    I know that's a bitter pill after you have opened so well but without reducing that CYA, you will need to keep your FC up around 10 ppm all summer and, well, that is a LOT of chlorine....much more expensive than the water to refill (about $50, I think...depending on your water rate)
    May 2014
    29
    Thank you for your response what is the correct way to drain /refills.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Since you have a vinyl liner pool, you never want to drain it all at once. You need to leave at least 1 foot of water in the shallow end of the pool to prevent the liner from shifting. We recommend you drain no more than 50% of the pool's volume at one time. After the drain refill the water, circulate for an hour and re-test. Report your results here.
    Love TFP? Become a
    TFP Supporter!
    Casey's Avatar
    SW PA
    10,444
    You can use a main drain if you have one or a sump pump.
    Welcome to TFP! Congrats on ordering the TF100 test kit and wanting to take back control of your pool. While you're here waiting for your pool to drain and refill, check out these articles in Pool School:
    ABC's of Pool Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Chlorine CYA Chart
    PoolMath
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    You're not THE Jersey Mike are you?
    Welcome anyway.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP Mike !
    The others above got you covered. Post up your results after your water replacement and we'll get you pointed in the right direction. 😎
    Jeff
    May 2014
    29
    Welcome anyway.
    Noop
    May 2014
    29
    Thanks for all the replies will keep you updated
    massimo's Avatar
    Jun 2013
    Manahawkin, NJ
    40
    Welcome to TFP! Once you drain and you follow the tips you find on this site you'll take your pool over! The feeling is liberating! It'll all begin to make sense, just gotta hang in there. Just drain and refill. Check back in with us after you begin to refill your pool and we will point you in the right direction. It's that simple!
    Massimo
    15X30 AG Vinyl (10,600 GAL) Hayward Power-Flo LX 1.5hp
    Hayward Sand Filter, Pool Rover JR, 12ML Solar Cover,
    TF100, BBB Method! POOL SCHOOL
    I Don't Get "Pool Stored!"
    May 2014
    29
    starting the drain today .Happy Memorial Day everyone and thank you to all that have served and are serving GOD SPEED
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    I had responded to the other Thread you had on this subject (which I have since deleted). I had basically suggested what you are doing (a drain & refill).
    Just FYI (and for the benefit of other members), the maximum reading of the CYA tube is 100. Whenever you get a result of "100" on the CYA test, it could be considerably higher than that which would impact how much water needs to be replaced. Therefore, you would want to repeat the test using these directions: Extended Test Kit Directions. Scroll down to post #8 for the CYA test. No need for you to do this now that you have started the drain & refill, just posting for future reference.
    May 2014
    29
    Quote Originally Posted by BoDarville View Post
    Thank You for all the help will keep updated
    May 2014
    29
    Quote Originally Posted by NJ Mike View Post
    FC 6
    CC 1.5
    TC 7.5
    CH 300
    TA 130
    CYA 100
    Good Morning after partial drain and fill part 1.my new reading are
    PH 7.2
    FC 1
    CC 1.5
    TC 2.5
    CH 225
    TA 90
    CYA 70
    Hope im heading in the right direction at this point should i drain and refill pool again or can we work with this Thanks Mike
    May 2014
    29
    this is what water look like
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I see you have a CC 1.5. Your water looks clear but your FC level is way to low. I would bring your FC level up to SLAM level for your CYA level which is 28. That may knock that CC down.
    If it were my pool I would want the CYA level lower. 50-40. IMO the pool is easier to maintain there.
    Now with that said, your CYA level of 70 is doable. You just have to stay on top of your FC levels so it doesn't fall below the min. For that CYA level I would be targeting 9 and don't let it fall below 5. You don't want to have an algae outbreak at that CYA level, it just makes you have to use more bleach for the SLAM process. 😎
    Jeff
    May 2014
    29
    Quote Originally Posted by pwrstrk View Post
    Now with that said, your CYA level of 70 is doable. You just have to stay on top of your FC levels so it doesn't fall below the min. For that CYA level I would be targeting 9 and don't let it fall below 5. You don't want to have an algae outbreak at that CYA level, it just makes you have to use more bleach for the SLAM process. ��
    I agree with you with CYA level 50-40 ,back to the drain and refill part 2 .will keep everyone updated Thanks Mike
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Mike you also need to get some chlorine in the pool ASAP or your going to be fighting algae. I don't think you want to do that process. Bring it up to SLAM level for your CYA level. Your CC's are a little high.
    Jeff
    May 2014
    29
    procees already started for 2nd drain and fill ,will have to start slamming after i refill hopefully time will be on my side
  20. Back To Top    #20
    May 2014
    29
    question how do i calculate bleach for the slam ,example fc 1 cya 60 do i use target fc # OR FC SHOCK #
