Results 1 to 9 of 9
Thread: 2 speed pumps and Caretaker 99 in floor system
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    I would like to get a 2 speed pump for the energy savings , I have a careTaker 99 in floor cleaning system and wonder if it wont function properly due to the lower pressures?
    Anybody using one ?
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    Re: 2 speed pumps and Caretaker 99 in floor system
    The CareTaker will require high speed to be able to clean the pool. You can run on high speed part of the time to clean and then run on low speed the rest of the time for general circulation and that will save some electricity, but not as much as if you didn't have an in-floor system.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Thanks for the reply !! Guess i will stay with the single speed cause the caretakers work really well and i want to keep them ( I also have a lifetime warranty on the whole system !!! )
    Sean Hannon
    tucsontico's Avatar
    Mar 2014
    202
    Quote Originally Posted by Seanhan View Post
    I just did an energy cost calculation today on my system. I, too, have an in-floor cleaner which I think is awesome! My pump is a Pentair 3hp VS and I'm running the in-floor cleaner at 2600 RPM and the circulation system at 1600 RPM. According to the EasyTouch panel, those speeds consume about 1100 watts and 500 watts, respectively.
    My electricity costs about 11 cents per kilowatt-hour and I run the system a total of 9 hours per day–6 hrs on high speed, 3 hrs on low. Doing the math equates to about 89 cents per day to run my pool equipment. I haven't done a life-cycle cost comparison of a single speed versus 2 speed versus variable speed pump, but I can tell you I am very glad I got a VS pump! It allows me to dial in the whole system and I am still tweaking it after 1 year of operation!
    Good luck!
    Has anybody tried the new VS pump from Circupool , I got a email add last week from Discount salt systems and they are selling them.
    http://circupool.mybigcommerce.com/v...ter-pool-pump/
    I have not but I definitely would read these stickies in this forum: Hydraulics 101; Pump Ed 101; Pump and Pool Spreadsheets; Pump Run Time Paper . Good Luck in your search!
    19,500 gal, 16' x 38' PebbleTec IG Pool, Built 4/2013; Pentair IntelliFlo VS 3050 3 HP Pump, Pentair Intellichlor IC40 SWG, Pentair IntellipH, Pentair 520 sq ft/150 GPM Cartridge Filter, A&A In-Floor Cleaner, Dolphin Nautilus Plus Robot (aka "Robbie"), Pentair EasyTouch Power Panel w/ Quick Touch 4 Remote Control, Autelis WiFi controller, Clear 12 mil Solar Cover on Presto SS Reel, Taylor K-2006 Test Kit.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    I have in floor and a VS Pump as well. I run at 1700 RPM for 10 hours, and 2850 RPM for two hours. I also have a suction side cleaner that I run a couple times a week.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    mas985's Avatar
    Pleasanton, CA
    11,742
    Both of you seem to be running your pumps for a very long time. Any reason for that and have you tried shorter run times? Also, if you want to save a bit more on energy you should try 1000 RPM on low speed and see if that works for you. 1600 & 1700 RPM is pretty high for a VS and will use much more energy than 1000 RPM which is around 140 watts.
    But for comparison to a two speed, my pump uses about 1150 watts on high speed and 250 watts on low speed.
    Mark
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Sean Hannon
    tucsontico's Avatar
    Mar 2014
    202
    Quote Originally Posted by mas985 View Post
    You are correct that I am running my pump at longer than the most efficient timing. My SWG is plumbed on the high speed (in-floor cleaner) side and, due to my pool's location in full sun, I have to run it 6 hours/day to produce enough chlorine. I am still testing speeds versus flow rates on my in-floor cleaner. To date, 2600 rpm works well to properly sweep the bottom and sides. There is more experimentation to follow!
    Also, since I have a venturi-driven skimmer, I also need a little more flow on the low speed side to get a decent skimming action. While I really like my pool's shape, I believe the I could've designed a better shape for pump hydro-dynamic purposes but the aesthetics overruled that!
    elwood58's Avatar
    May 2012
    654
    I run my pump for twelve hours here in the Arizona sun. I may knock it back a couple hours when I get the seasonal change dialed in. I run a HeatPump/Chiller combo as well. 1700 is needed to meet the flow requirements of the HeatPump. The 325 watts used at 1700 is a fraction of what my single speed pump was using.
