Thread: Help
    May 2014
    PA
    1
    Help
    I am trying to replace a stripped out nut sleeve on my de filter the problem i am having is the new seems a little to small. The store keeps telling me it is the one for my filter just wondering if the old ones stretch which makes them thread on so easy. And if so do put the new one on even if it seems to tight. My concern is i am going to strip out the new one!
    Thanks
    Dhoags
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Help
    If it's the right thread, it should go on by hand, even if it's a bit stiff. The ends of the threads aren't banged up are they?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: Help
    If the threads aren't banged up try putting a little silicone pool lube on the threads and see if that helps. If that doesn't help you may need to take both parts to the pool store so they can try and match it up.
    Love TFP? Become a
    TFP Supporter!
