Thread: Replacement Circulation Pump Motor Advice
    Hello,
    My 3/4 HP Hayward Northstar circulation pump motor has gone kaput. I've researched variable speed, single speed, and 2 speed replacement options but have only succeeded in becoming confused. Have no real preference for either type. Looking for overall most cost effective solution. Hoping that the experts on this forum can help lead the way. Here are the stats:
    - 19,000 gal IG plaster w/connected spa overflowing to pool
    - separate jet pump for spa
    - separate pump for roof mounted solar
    - Hayward Navigator suction side pool cleaner
    - all 2" plumbing at equipment pad
    - 325 sf cartridge filter
    - 220V wiring
    - Jandy RS4 controller (vintage 2003/2004, don't think it operates VS or 2 speed pumps)
    - average cost/KWh = $0.19
    - utility company rebate of $100 available for VS pump
    Any advice would be much appreciated. Thanks!
    19K gal gunite, pool/spa combo, built 2004
    Hayward cartridge filter, Hayward 3/4 HP single speed pump
    Hayward Navigator cleaner
    Jan 2013
    Houston, TX
    1,079
    Re: Replacement Circulation Pump Motor Advice
    I would go 2 speed and put a high low switch on the pump.
    Which 2 speed motors are you looking at?
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
