Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Added 11 jugs Clorox Concentrate and FC still at 1.5 ppm
    tzanco's Avatar
    Apr 2014
    Marlboro, NJ
    8
    Unhappy Added 11 jugs Clorox Concentrate and FC still at 1.5 ppm
    I'm new to pooling and last year (when we moved in) I used the pucks and shock that the pool told us too. It didn't work well. This year I found the forum, bought a tf-100 and discovered my CYA is 180. I emptied 2/3 of the pool and now CYA is 80. Still high but I'll get it down over time.
    We opened the pool a couple of weeks ago but I cannot get the FC up at all. At first I added 3 jugs to get up to the minimum 9ppm per the CYA/Cl chart. I didn't test it right after I added it but the next day's test showed 1-2 ppm (OTO and FAS/DPD). Another 4 jugs go in and the same thing.
    Today I added 11 jugs of Clorox 8.5% from Costco then tested after 1.5 hours and my FC is still 1.5ppm! This is driving me up a wall and into the poorhouse. What's going on here?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Added 11 jugs Clorox Concentrate and FC still at 1.5 ppm
    Welcome to TFP!
    More than likely you have some kind of contaminant using up chlorine rapidly. You should follow the SLAMing Your Pool process to get the chlorine consumption under control.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,993
    Welcome!
    What does the pool look like? Can you even see through the water? If there's a lot of debris in the bottom, it will use up all the chlorine before it can work on the algae.
    Check out some threads of people who've done it
    First Time Shocking with Bleach
    Pretty black pool
    A little encouragement for those with algae and new to BBB
    Frog Filled Green Swamp to Oasis---Work in Progress!!!
    Before and After Pool Pics
    Before and after!
    A final picture set of how well the BBB method works!
    And who are still doing it: http://www.troublefreepool.com/threa...h-help-on-pool
    tzanco's Avatar
    Apr 2014
    Marlboro, NJ
    8
    Hi Richard - The pool is 80% clear. The deep end is a bit murky but not terrible and not green.
    Hi John - That's what I'm trying to do wouldn't you expect the FC to increase by a little at least? You'd expect it not to budge at all?
    Quick side Q: Are the methods espoused here cheaper than using the store pucks and raising the CYA back to the stratosphere, or is it just a better method to keep the pool balanced?
    30k gal, IG vinyl, polaris with a mind of its own.
    Our recommendations are far less expensive than what most pool stores recommend. There are other approaches that are about the same price as ours, but you don't see them mentioned very often.
    Ammonia in the water uses up chlorine very very quickly, before it even mixes in throughly. You can never get an FC reading as long as there is still ammonia. Once you have burned off all of the ammonia, you will be able to hold an FC level again.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    What is your cc reading
    The method here is cheaper. I used to spend $400 plus now I spend $75.
    tzanco's Avatar
    Apr 2014
    Marlboro, NJ
    8
    cc is still 0. pool is completely free of debris now but still murky and the FC won't hold at all (won't rise at all).
    I already spent $90 in bleach, $75 for the year would be amazing.
    PS, pool store this morning told me that 'adjusted' TA is what we should be looking at, which is function of TA and CYA. Is this true? Pool math and the recommended levels table both just state TA.
    Could you post a complete set of water test results?
    tzanco's Avatar
    Apr 2014
    Marlboro, NJ
    8
    of course, sorry! as of 10 minutes ago:
    fc 0.1
    cc 0
    pH 7.2
    TA 100 (per tf-100) 75 (per pool store)
    CYA 80 (per tf-100) 100 (per pool store)
    Just added 48oz soda ash to increase pH
    With CYA at 80, shock level is 31. If I am following correctly, you raised the pool to shock level once and it went back to FC at 1.5 in under two hours.
    CC at zero argues against ammonia. I can't think of anything else that could use up that much chlorine that quickly and yet not drive FC to zero.
    Perhaps it is time for an extreme chlorine demand test.
    tzanco's Avatar
    Apr 2014
    Marlboro, NJ
    8
    Quote Originally Posted by JasonLion View Post
    OK just finished the ECDT. I used a 3gal bucket (all I had) and 1 oz of 8.25% bleach. After 1 hour I tested for FC and it stopped the dropper at 45 ppm. Sounds like I passed? Does this mean that I need to add a poop-ton of bleach to the pool?
    Yea, quite a bit of chlorine. The ECDT says that it should be less than 50 ppm of chlorine to resolve the problem. We can't tell where between 1 ppm and 50 ppm it will actually be without more testing. You can do the testing, or just go ahead and start adding chlorine in batches and test an hour after each batch to see if you need more.
    tzanco's Avatar
    Apr 2014
    Marlboro, NJ
    8
    I'm paying $8.59for 3x121 oz 8.25% bleach. Is that an ok/good price?
    Check the bleach prices 2014 topic to see the best prices others are getting these days.
    Jun 2011
    Long Beach, CA
    2,784
    If you can, I recommend replacing 50% more of the water to reduce the CYA to 40 and that will make SLAMing the pool much easier.
    tzanco's Avatar
    Apr 2014
    Marlboro, NJ
    8
    Pool math says I should add 11 jugs of 121oz 8.25% bleach. I did this previously and it didn't do anything to FC. Is pool math wrong if it turns out I need to add ton more than 11 jugs?
    That is the most you should add at one time. I would add about 5 jugs now, and more later if need (likely but not certain). Test after an hour and see where you are. As long as FC continues to fall below 2 after an hour (or two or three), keep adding 5 jugs at a time. You can add more at a time if you want, but not more than 11 jugs at a time.
    Quote Originally Posted by tzanco View Post
    That's what I'm paying, but other people have done better.
    Something is eating your chlorine. That can't last forever. Once you burn that it up, things will get better fast. Ignoring sunlight. You can't use that up.
    20,000 gal in-ground plaster pool with sand filter. Replastered recently. Mostly adding bleach and acid. CYA was high when I took over.
    Ellington, CT
    262
    According to this http://poncatechsquad.com/Dan/Chlorine/ it calculates out to $0.287 per oz of chlorine which is consider fair. If you are close to Shrewsbury NJ, there is an Ocean State Job Lot store where you can get a gallon of 12.5 % Liquid Chlorine for $2.99 or $0.187 per oz. Here is CT at the OSJL that I go to, the stock moves fast and its always fresh, you just have to make sure to check the dates on the boxes.
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
  20. Back To Top    #20
    tzanco's Avatar
    Apr 2014
    Marlboro, NJ
    8
    Emptied 2/3 and refilled. Now down to 55 CYA. Wish me luck!
    Pool store this morning told me that 'adjusted' TA is what we should be looking at, which is function of TA and CYA. Is this true? Pool math and the recommended levels table both just state TA.
