- Feb 2, 2012
- 272
I received my TFPC Test Kit earlier this week and did my first test today. This is on a 40,000 gallon gunite pool in FL with a salt system & nature 2 (I know I might get blasted for using Nature 2 ) Here are the results
Ph 8.5
Calcium 350
TA 120
CYA 10
FC 1.0
CC 0
TC 1.0
So according to the Taylor book it says I need to add about 3.5 gallons of Muriatic acid. And I also need to add stabilizer, I'm a little hesitant on adding the stabilizer as the last time I did this I added it directly to the pool and it turned instantly cloudy for 2-3 days. What is the best way to add stabilizer? Also is it okay to add that much muratic acid to the pool at one time or should I do that over several days? What is the best way to add the muratic acid to the pool. Also any other suggested would be greatly appreciated, thanks for the help and I'm excited to start following the TFPC method.
Ph 8.5
Calcium 350
TA 120
CYA 10
FC 1.0
CC 0
TC 1.0
