Thread: New Laterals
    Exclamation New Laterals
    Ok. I was getting sand in my pool so I installed new laterals. I didn't see anything wrong with the ones I took out but replaced them anyway. I turned on the pump on rinse and forgot to open the return valves. i got tons of blowback sand out or the line that i plug my auto cleaner into. turned it off and realized they were closed. i backwashed the filter good and I'm seeing lots of sand in the sight glass when i have it on rinse. any suggestions??
    Jeremiah Hough
    22,000 gallon, vinyl liner, chlorine, with auto cover
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: New Laterals
    Stretch a nylon over the return and hold iot one with a rubber band and catch what you can. If it eventually stops, problem solved.
