Results 1 to 7 of 7
Thread: Pool Cover and A-Frame ladder
    Mandolina's Avatar
    Apr 2014
    Los Angeles USA
    67
    How does one cover the above ground pool with an A-Frame ladder in it? In southern California we get some heavy duty winds and I would like to keep the debris out. Thanks.
    16' x 48" 5000 gal. Intex Ultra Frame AG Pool, Los Angeles, CA
    Hayward Full-Flow Cartridge Filter System with 2 Speed Power-Flo Matrix Pump,
    Intex SWG, Intex Wall Mount Surface Skimmer, Solar cover & Solar Roller,
    Confer Plastics A-Frame 7200 Adjustable Roll-Guard Safety Ladder,
    Kokido SkoobaMax Vac, Custom Canine entry & exit ramps,
    Casey's Avatar
    SW PA
    10,461
    Re: Pool Cover and A-Frame ladder
    You take the ladder out of the pool.
    Mandolina's Avatar
    Apr 2014
    Los Angeles USA
    67
    Quote Originally Posted by Casey View Post
    Darn - that's hard when the ladder is bolted to the frame and the legs are filled with water. I wish there was another way to cover the pool without removing the ladder.
    Orlando, FL
    690
    I cut my solar cover to fit around it.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Casey's Avatar
    SW PA
    10,461
    I thought you were talking about a winter cover for end of the year. I'm sorry.
    I have cut around my ladder too.
    Mandolina's Avatar
    Apr 2014
    Los Angeles USA
    67
    Yes, I was referring to the pool's cover, not a solar cover. I wanted to be able to put it on and off, like a car cover, when the weather turns inclement. In southern California, we can have sunny one day, rainy on the next, and high winds on the third. I guess the solar cover will have to suffice. - Thanks!
    Casey's Avatar
    SW PA
    10,461
    You'll have to remove the ladder to use the pool cover.
