Thread: Green water after clearing the stains
    I have recently used Stain Free from Natural Chemistry to clear the iron stains on my skimmers and light/return fixture. The stains did clear, so I added Metal Free maintenance dose (I have already put the initial dose & now maintaining). The water was clear for about 24 hrs, then it turned very cloudy, and I found no FC when I tested. I suppose that algae started when the FC was down to 0 ppm for the Stain Free dosage.
    I shocked it to 20 ppm, on Tuesday night, and noticed that the iron stains are back on Thursday morning. I added more of the Metal Free, about 6 to 7 oz, and an hour or so later the water is green.
    This moring, Thursday, my readings are:
    FC 15.5
    CC trace
    pH 7.6
    T/A 170 ( it does run high)
    CYA 40
    CH 260
    PLEASE advise what I should do. Thank you very much for the help in advance 8)
    My little bit of Heaven :)
    A/G, 13,050 gal, sand filter, vinyl liner
    AquaVac Tiger Shark robotic cleaner
    Re: Green water after clearing the stains
    You need to be really careful about shocking right after a stain treatment. You should read the Pool School article on metals and the ascorbic acid treatment artile it links to for more details and possible solutions.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I was reading Waterbears stain treatment article yesterday and he said be sure to use PolyQuat 60 algaecide to prevent an algae bloom while doing a stain treatment, and not to shock for 2 weeks following the stain treatment. Bring the FC up slowly, using sequesterant to keep the staining from returning.
