Results 1 to 10 of 10
Thread: My head is about to explode!
    Medeco's Avatar
    May 2014
    Atlanta
    17
    Hi guys,
    You must get tired of the newbies coming on here, but its awesome to see the help. Ive been lurking, reading as much as I can including pool school.
    Brand new vinyl pool with SWG, sand filter, about 35k gallons in size.
    Thought I was getting close, then I took my sample into the store to back me up. Im now confused.
    Used the pool calculator and added just shy of 2 gallons of Clorox bleach last night. First thing this morning the test showed near perfect FC. Using a Leslie's complete poolcare DPD test kit.
    3hrs later tested again and FC is 0, so I took a sample into the store.
    Stats:
    Water is clear
    FC-0
    TAC-0
    Salt- 3000
    CH- 100
    CYA- 50
    TA- 110
    pH-7.6
    copper-0
    iron-0
    Phosphates- 200
    Store guy was confused too, when I shared the FC stats and how I added the liquid bleach.
    Currently running the SWG on boost, and added 2 lbs of granular chlori-brite.
    What do you recommend? Thanks!
    38,239
    Re: My head is about to explode!
    Welcome to TFP!
    Only 2 things consume FC, the sun or something in the water. With that CYA, the sun is not likely the problem. So, must be something in the water.
    So, the SLAM process is likely what is needed. But to do that, you will need the FAS-DPD chlorine test added to your kit.
    Post your numbers, not the pool stores which are notoriously inaccurate and inconsistent.
    Also, stick with liquid chlorine or you are going to make your CYA higher and have to use higher FC level for the SLAM. You can raise it a bit after the SLAM.
    Medeco's Avatar
    May 2014
    Atlanta
    17
    Ok, thanks for confirming my thought to slam. I know its not safe to swim with FC at zero, but cannot find a definite answer on swimming while slamming. Maybe its obvious...
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Definite answer>>>> It is safe to swim up to SLAM level per your CYA. But NOT if you can't see the bottom clearly.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by Medeco View Post
    Trust your own test results.
    That test kit you have is the K-2005. They probably sold it to you telling you it was the same as the K-2006. It's not. You're not the first to have that happen to them. The good news is, adding this will bring you up to a K-2006. With the FAS-DPD test (which is not the same as the DPD test) you'll be able to read your chlorine to within .2 parts per million and do an overnight drop test. That will tell you for sure if something is growing and eating your chlorine or not.
    Don't dump any more powders in your pool!! That Chlor-brite is Dichlor. MSDS In a pool your size, 2 lbs only added 3.8 FC, but it added 3.5 CYA as well! And lowered pH by about .14. With a SWG, that's not all bad, but if you need to SLAM, that means the chlorine level needs to be even higher!
    You have a test kit. Believe it. If you're unsure if you're testing correctly, watch the videos. But trust yourself. The sample is fresh and the kit is accurate. And nobody's trying to push any products on you at home. They don't offer free testing to be neighborly, they do it to generate sales!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    exactly what Richard said.
    As a FYI, the Pool Store testing as well as their recommendations are notoriously flawed. Trust your test results, if there is a question, do the test again. And ask questions here and you'll get all the help you need.
    Have a great Memorial Day Weekend, and enjoy that pool !
    Divin Dave,
    Medeco's Avatar
    May 2014
    Atlanta
    17
    Thanks for all the tips. When I bought the kit, I had zeroed in on the Taylor 2005 from the internet simply from ratings more than knowledge, but they only had the 2006, and neither I nor they, knew what it offered that was different from the 2005. Oh well, easy fix.
    Should I be concerned about the phosphates level in my OP? Ive yet to read anyone talking about this.
    Apr 2010
    East Texas
    9,569
    Phosphates levels are largely meaningless-and that ain't much anyhow. Don't buy anything to fix it!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Hi, welcome to TFP! Please edit your signature to include information about the pool such as pool type (above ground or in ground), surface (vinyl, plaster, or fiberglass), size in gallons, pump brand and horsepower, filter type (sand, DE, or cartridge), filter brand and size, and any water features, cleaning systems, and if there is a spa (attached or detached). It will show up at the bottom of everything you post and it is easier for us to help you if we don't have to search the thread for this information.
    How does your water look, by the way? How long has the pool been filled? What is your source of fill water (municipal, well, ect...)?
    Love TFP? Become a
    TFP Supporter!
    Medeco's Avatar
    May 2014
    Atlanta
    17
    Quote Originally Posted by zea3 View Post
    Done!
    Water is clear, pool has been filled since April 23, started pump and cleaning 2nd week of May, had fair amount of dirt in the bottom. Water is municipal.
    I'll update test stats in the morning. Thanks!
    IG pool, vinyl, 35k gallons, Hayward 1hp super pump series, Hayward top mount sand pump S244T with vari-flo XL, SWG-Saline Generating systems Breeze 540, Hayward SharkVac XL,
