Thread: Wiring Question on Jandy EPump and Aqualink
    May 2014
    New Hampshire
    2
    Hello everyone,
    First off, thanks in advance for reading this. Simple question I can't seem to get answered.
    I'm installing/upgrading to a new pump and controller. I went with a Jandy setup including the JEP 2.0 and an iAqualink controller in a power center (and salt water generator).
    With this setup does anybody know if I'm supposed to wire 230 directly to the pump, or should it go through relay #1 in the control panel. I've gotten two different answers on this topic and I figured if anyone knew it would be this group.
    Thanks in advance,
    Jon
    Re: Wiring Question on Jandy EPump and Aqualink
    Welcome to TFP!
    Other brands always have the pump directly connected to the breaker, and the Aqualink equivalent controls the pump through a data cable. I can't find anywhere that Jandy says that, but I assume it is the same for them as it is for the others.
