Results 1 to 19 of 19
Thread: OK, here we go. FIRST TEST!
    NemesisR6's Avatar
    May 2014
    Space Coast, FL
    23
    Ph = 7.5
    FC = 12.5
    CC = 0
    TC = 12.5
    CH = 625
    TA = 150
    CYA = 100+
    Bought this house about 1.5 years ago. Has been treated weekly by our local pool supply chain prior to moving in and since with chlorine tablets. "Technician" comes every Monday and typically adds new tablets to the chlorine feeder as required, shocks, and tests water for Ph. As I suspected for awhile, CYA levels are extremely high, and I wasn't even able to reach the maximum reading of 100 using my TF-100 test kit.
    I am located in central Florida and pool is used almost year round except in the coldest months. It lies on the west side of the house and gets direct sunlight for much of the day.
    Additional pool detail located in signature.
    Have had issues with in the past with algae growth (brown/yellowish color) that has been handled with shocking and/or algaecide etc.)
    Currently, the pool looks as the pictures indicate..........fantastic. However, I would like to take control of its treatment and get away from tabs as the primary source of chlorination.
    Looking forward to replies and can provide additional detail if requested.
    Thanks!
    15,000 gallon, plaster IG pool with WhisperFlo 1.5HP pump, cartridge filter, automatic TriChlor feeder.
    Jun 2013
    Fontana California
    56
    Re: OK, here we go. FIRST TEST!
    Welcome!!!
    I see a partial drain refill in your near future. I leave the rest of the advice to the experts.
    14K Gallon IG Gunite Pool built in 2005, Century Centurion 1 1/2 HP Pump
    Pentair Clean & Clear 420 Sqft. Cartridge filter, MiniMax Pentair NT Heater, The Pool Cleaner
    Taylor K-2005 test kit with Taylor K-1515-A FAS-DPD Chlorine Test. SpeedStir
    NemesisR6's Avatar
    May 2014
    Space Coast, FL
    23
    Yea, I'm anticipating that. However, our well water is very high in metals and stains quickly as well. Not to mention the flow rate is atrocious......
    I have contacted a local bulk water supply company who can up to deliver 6,000 gallons per trip if necessary.
    Oct 2013
    Chapin, SC
    1,141
    Depending on what your actual cya level is, and there's no telling what it is as is, 6, 000 gals may not be near enough to what it is ultimately going to take. A 6,000 gal drain just "may" get you closer to a realistic level, but no guarantee on that! Hope tor the best! First order of business is to stop using trichlor tabs and dichlor shock. If you don't, you will never get your pool under control. Read all you can of pool school, maybe several times! Order an adequate test kit-- a tf-100 or taylor k-2006, either can be found@ tftestkits.net. post your results here when you have them.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    NemesisR6's Avatar
    May 2014
    Space Coast, FL
    23
    Quote Originally Posted by timerguy View Post
    So there's no way to get accurate CYA readings using the TF-100 beyond 100?
    Are there other tests on the market that will get me an accurate reading? I'd rather not go in blind.......
    Oct 2013
    Chapin, SC
    1,141
    http://www.troublefreepool.com/threa...Kit-Directions as a matter of fact you can use the dilution test to get you in the ballpark. But, for sure a 50% drain will be the minimum required!
    Jun 2013
    Fontana California
    56
    Another option besides a drain/refill is Reverse Osmosis.
    Click this link: Reverse Osmosis
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Quote Originally Posted by NemesisR6 View Post
    Not as accurate as you'd like, but plenty good. It's the dilution method. http://www.troublefreepool.com/threa...Kit-Directions
    NemesisR6's Avatar
    May 2014
    Space Coast, FL
    23
    Directions call to use tap water. Since we have a well with a water softener, should I just use bottled water?
    Richard320's Avatar
    Jan 2010
    18,984
    For the CYA test, either works. Just so long as it doesn't have CYA in it.
    NemesisR6's Avatar
    May 2014
    Space Coast, FL
    23
    Well, I did the diluted test 3 times.
    Each time I stopped at 100 CYA, so that means I have 200 CYA in my pool.............no wonder it has been taking so much chlorine to keep it healthy. Talk about the law of diminishing returns.....
    OK, so obviously the CYA needs to be corrected before I can really proceed very far, which means:
    - Near complete drain/fill. Based on quotes I've received, this will cost approx. $700 based on the size of my pool.
    - Reverse osmosis. This is the first I've heard of this option, so I will have to call around and find out who might provide that service.
    Am I correct in assuming that I can't do much until I get acceptable CYA levels?
    30,414
    Why not just do several partial drain/refills?
    In FL, I assume your water costs are less than 8/1000 gallons so that should be less than $100 bucks unless I am missing something.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Dave he is on well water with metals.
    I doubt you will find an RO treatment option in FL, they are mostly marketed to the high CH regions of the country like the southwest, CYA reduction is a secondary effect for most of their customers. As to water check with your local volunteer fire departments in some areas they will deliver water for a small donation.
    Ike
    NemesisR6's Avatar
    May 2014
    Space Coast, FL
    23
    As I've said, I'm on a well water system. Not only is our well water very high in metals (hence our softener), but the flow-rate would require I run my pumps nearly round the clock for a week to get the pool drained/refilled.
    Bulk water delivery runs for $350/trip at 6,000 gallons each run. They can offload all 6,000 gallons in about 25 minutes.
    Richard320's Avatar
    Jan 2010
    18,984
    That sounds awfully high for water. Also, call the water company. Sometimes they offer a variance to the rates for pool filling, if you set it up in advance. They'll often waive the sewer fee if that's based on water consumption.
    And since you're in Florida, you probably don't want to empty it all at once, lest you float the pool. You think you got problems now?
    NemesisR6's Avatar
    May 2014
    Space Coast, FL
    23
    Quote Originally Posted by Isaac-1 View Post
    Ike
    Based on the calls I've made I'm already discovering this. Nobody does RO treatments at that scale, just for small applications like tap-water.
    I talked to my friend with the local fire department last week. They stopped doing delivery when one of their trucks ran over some guys septic drain-field and crushed it. He sued. They pulled the plug.
    NemesisR6's Avatar
    May 2014
    Space Coast, FL
    23
    I don't deal with the water company. I have a well/pump and a septic system.
    Our house was built in the last 10 years, so the building code calls for a significant amount of fill dirt to bring the foundation about 6-7 feet above original ground level. In other words, my house is built on top of its own personal hilltop. The pool itself is well above the existing water table, but I would take the necessary precautions regardless if I were to go the drain route.
    Wow to that video!
    Casey's Avatar
    SW PA
    10,428
    Just think, once you learn the TFPC way you'll never have to deal with this again.
    Welcome to TFP. Hope you read the articles provided to everyone in pool school.
