Results 1 to 8 of 8
Thread: Yellow Stains
    Yellow Stains
    Had yellow staining on stairs after opening this season. Wife flipped out, I stayed calm and went back to old reliable TFP and learned about vitamin C, worked like magic!
    IGVP 20X40 30,000
    Hayward 1.5gpm Superpump
    Blue Pearl Robotic Cleaner
    Dad, can we go in yet?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Yellow Stains
    I just saw what you did!!!
    30,405
    Re: Yellow Stains
    Now that is just plain cool!! Thank you for sharing!
    Jan 2013
    Houston, TX
    1,079
    Re: Yellow Stains
    Awesome!
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Casey's Avatar
    SW PA
    10,427
    Re: Yellow Stains
    Wow... you're dedicated!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Yellow Stains
    Showoff!
    Love it! You get a gold star!
    You're done SLAMing when:
    Re: Yellow Stains
    Would this work on some leaching stains from leaves? I have some stains on my stairs when I opened this year. I was also thinking of putting a chlorine puck on the stain.
    29,000 gallon irregularly shaped in ground pool. Plaster. DE Filter. 1 hp pump. Pool approximately 10 years old. Polaris 380 robotic cleaner. Middletown, Delaware.
    Richard320's Avatar
    Jan 2010
    18,967
    Re: Yellow Stains
    Quote Originally Posted by pats300zx View Post
    Vitamin C is for metals. Organic stains need chlorine. Setting a puck will likely bleach it, but pucks are acidic and might etch the plaster. A better bet would be just keep your FC at the high end and be patient. Make sure you get plenty of water circulating around the steps, even if that means brushing more. And when you add bleach, add it near the steps and then brush good so they get a good jolt before it mixes.
