Thread: Should I shock?
    Should I shock?
    Please start your own thread if you have questions about your pool. Then answers intended for you are not confused with answers intended for the one who started the thread. Thank you, Zea3
    Hi opened my pool today pump is running and water is crystal clear dirt on bottom. Here are my readings
    FC 1.6, cc .2, ph 7.4, ta 90, calcium 90, cya40
    I guess my question is should I shock? Probably get free chlorine up some everything else looks pretty good to me?
    19,700 gallons non SWG
    Pentair DE quad 100 filter
    Auto chlorinator and nature 2
    Inground pebble
    Intelliflo variable speed 3 HP pump
    Re: Easy opening
    Those are not my numbers, I have a chlorine pool 19500 gallons
    Inground pebble
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Should I shock?
    Quote Originally Posted by micmlm View Post
    It doesn't look like you need it, really. CC is really low and you have no algae. By the way, we don't use that S word as a verb around here. "Shock" is a generic term for chlorine powders. We use the term SLAM.
    For peace of mind, you could take it up to SLAM levels all day and run the overnight loss test. If that passes, you're done with the SLAM in one day. It might waste a couple jugs of bleach, but that's all.
