Thread: 2hp 2 speed pump w/ 150sq' filter
    Mar 2014
    NW suburbs IL
    31
    Will running a 2hp on low speed achieve same results of a 1 hp motor? Is 150sq' filter large enough for 24' round 54" AGP? Please advise. Need to pay for pool today and install is Wed.
    Mar 2014
    NW suburbs IL
    31
    Re: 2hp 2 speed pump w/ 150sq' filter
    Purchasing pump and filter together in package. I will upgrade and or change later as I become more familiar w pool. Just need to get started choices is package are limited.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    That's what I have and I run the pump on low 24/7. I use high for vacuuming.
    Can you get a nice sand filter as part of the package?
    patrick3229's Avatar
    Feb 2012
    263
    The low speed would be much less than 1 hp probably more in the range of .25 horse power. The 150 sq ft cartridge filter would be plenty large enough for that size pool.
    Thank You
    Patrick
    www.inyopools.com
    Low speed is 1/8 the HP of high speed, so 1/4 HP in this case. That is plenty for this pool, and you still have high speed for times when you might need it, things like vacuuming or cleaning up algae.
    Mar 2014
    NW suburbs IL
    31
    Probably but will do that down the road. Have connections for future pool equipment. Just want to get things up and running right now.
    24' round AGP 54" recessed 2' in ground, 2hp 2 stage Hayward pump, 150 sq' filter
    Install on May 28 2014
