Results 1 to 10 of 10
Thread: Pump won't filter.
    May 2014
    Maryville, Tennessee
    4
    Pump won't filter.
    I tried to open my pool and back washed my filter, then rinsed. I then turned valve to filter, and noticed no pressure coming out of the return. Help! Thanks in advance. The filter is a jacuzzi model.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Pump won't filter.
    Welcome to TFP!
    I'm not familiar with that filter, so can't be much help. However, there are many others here that can.
    To help them help you, could you add your information, as outlined here?
    No pressure or little pressure? My guess is that its either a DE filter or Cartridge filter and the elements need to be acid washed. I am always in the same boat every year I open the pool.
    pool size - 40kgal
    finish - Gunite
    pump size in horsepower and brand-Variable Speed, Hayward EcoStar SVRS3400
    filter size - Sta-Rite S8M150
    additional equipment - Hayward CL220 Chlorinator
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome Earl!
    Is this a Sand filter?
    Essential Links:
    May 2014
    4
    Quote Originally Posted by Brushpup View Post
    Welcome Earl!
    Yes, this a a sand filter.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Is this an inground pool? Is there water in the pump basket?
    May 2014
    4
    This is an above ground pool, 24ft. Around. it will backwash, and rinse fine. But when put on filter, there is no pressure at all coming out to filter the water.
    Yes.
    11,969
    Is the motor running, humming? Sounds like it's not pulling - maybe the impeller is stuck. You handy with taking things apart?
    Silly question but you sure there's no shut off valves that you forgot to open?
    May 2014
    4
    My strainer basket housing cracked, and I had a friend replace it. A simple unscrew. two parts.....the housing and o- ring.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    The only valve that would cause this would be on the filter out pipe. Do you have a heater? If yes, does it have a 3 valve bypass set-up?
    Rather than having us guess about your equipment, could you fill out your profile etc as I had asked in the first reply?
    Also, if your have a few pics of your equipment, that would be helpful also.
