Results 1 to 7 of 7
Thread: CH levels ~100, liner feels like sandpaper
    Jun 2010
    NW Foothills of North Carolina
    21
    After the pool had clear (can see the drain) and vacuumed pretty good, I finally did my first test this week.
    FC = 0.5
    pH = 7.5
    TA = 50
    CH = 70
    CYA = Didn't test.
    So I added 14 lbs of sodium bicarbonate, added 5 lbs of calcium chloride (bioguard Balance pak 300), 4 lbs of stabilizer, 121 oz of 12.5% bleach.
    Today, I did another test.
    FC = 0
    pH = 7.2
    TA = 60 (66 at pool store)
    CH = 105 (117 Hardness at pool store)
    CYA = Didn't test. (10 at pool store)
    Then I noticed that the liner felt like sandpaper. I had read that it could be scaling, so I had the pool store to test the water also, to make sure my test kits are still working. So is it calcium, or do I still have an algae problem? Does any algae feel like sandpaper? My brush doesn't remove it.
    21K gallon, 16 x32 IG Vinyl, 3/4 HP Hayward Superpump,
    200 lbs Sand filter, Full sun all day
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: CH levels ~100, liner feels like sandpaper
    No sounds like calcium scale. If this is new, you can keep the PH at 7.0 for a couple of weeks and brush daily to try to dissolve it. You can also try a scale treatment purchased from a pool store.
    Quote Originally Posted by flash View Post
    Can you describe how you added those products?
    Your readings don't indicate that scale would be likely. However, If the calcium and bicarb combined on the floor, then they could form the type of scaling you describe.
    Support the site
    Jun 2010
    21
    I weighed the 14 lbs of bicarbonate, then walked around the pool spreading (throwing) cups of the the sodium bicarbonate into the pool. Then added the calcium the same way. I did not wait. I added the bicarb, then measured the calcium and added it to the pool. After that I brushed the bottom of the pool. I also don't know if the sandpaper feeling was there the day before. I just felt it when I was adjusting the returns.
    Casey's Avatar
    SW PA
    10,427
    Why did you add the Calcium? Vinyl pools do not need Calcium.
    Adding calcium directly on top of the bicarb is the likely cause of the scale. Try lowering the pH for a while, as suggested by FPM. Brush daily.
    Note: Brush lightly. If you scrub the scale too hard, you might damage the liner. Patience is key.
    Also, I would recommend avoiding adding any more calcium or any pH increaser.
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I agree with James, please don't add any more of those.
    Lower the pH, keep it there and brush lightly...a lot and see if it doesn't improve. I bet it will.
    Essential Links:
