Thread: Plumbing The Intex Krystal Klear SWG
    Jul 2007
    Hillsborough, NC
    525
    a standard 2" threaded PVC fitting will screw onto the Intex SWG. You just need a lot of pipe dope. From there it is simply a bushing to adapt to 1.5" PVC pipe. It is better to have the union as close to the SWG as you can get it. It makes disconnecting and storing easier.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Plumbing The Intex Krystal Klear SWG
    The threads on the Intex equipment are a metric 50mm straight thread, close in pitch to the NPT 2" taper thread. Yes, they mate up, almost, but not quite. The actual closest you will find is the American fire hose 2" straight thread, designed to use a gasket.
    Jul 2007
    Hillsborough, NC
    525
    Thanks for the clarification. The fitting is apparently close enough, since it is working with no leaks. Looking at the prices here
    https://flexpvc.com/cart/agora.cgi?&...etric-Adapters
    The pipe dope solution is working just fine. I could of course use the intex supplied parts but that would mean reducing the ID of the pipe and getting some flow restriction
