Page 1 of 2 12 LastLast
Results 1 to 20 of 37
Thread: Cloudy water TA finally down
    May 2014
    Missouri
    14
    New to this. I just got the TA down with muratic acid. My pool is very cloudy. What should I do next?
    Re: Cloudy water TA finally down
    Welcome to TFP!
    Please post a complete set of water test results.
    May 2014
    Missouri
    14
    All I have is hth test strips so it's real hard to tell exact numbers
    It is essentially impossible to know what is going on with the water without test results. A high quality test kit is indispensable and will save you lots of money and time going forward.
    In the meantime, give us what you have and we will see if we can figure out what is going on from that.
    May 2014
    Missouri
    14
    Just done the test strip again. I guess the ta isn't down. It's finally on the charts tho. Blah, this is driving me crazy. I added a gallon of muratic acid today. Guess I'll get more tomorrow. Everything else tested good beside chlorine is at like 0.
    How do I find this thread without searching through all of them?
    Good, reliable test results are critical to getting and maintaining good water quality. Without actual numbers, it's difficult for us to help. A zero chlorine is insufficient. The correct chlorine level depends on your cyanuric acid level. You probably need to go through the Slam process.
    Support the site
    May 2014
    Missouri
    14
    How do I slam? Where and what test kit should I buy?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Both of those articles are in Pool School. Click on the tab at the top right hand corner.
    To find your post, click on the "my search links" tab.
    May 2014
    Missouri
    14
    I found that I need to add bleach but idk how much. 33 ft round. Approx 4.5 ft deep
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Hi, welcome to TFP! You can compare the test kits we recommend here . I feel the TF100 is the best value of all the recommended test kits and shipping is fairly quick.
    How much bleach you need to add is dependent on your CYA level. Without knowing current test results you are flying blind.
    Love TFP? Become a
    TFP Supporter!
    May 2014
    Missouri
    14
    According to the test strip the cya is between 50 & 100
    11,969
    It could be anything. The strips are worthless for reading anything accurately, except perhaps Ph.
    Can you get to a Walmart? They sell a 6-way drop based kit by HTH that can test for CYA for about $20. If you order the K-2006 from Taylor or the TF test kits TF-100, you'll have in a few short days. You need to be able to properly test - strips don't cut it... I'm sorry.
    Casey's Avatar
    SW PA
    10,450
    Wish we could give you concrete advice but as you have noticed, we all have our hands tied behind our backs waiting for you to make your next move which is to purchase a reliable test kit. I would caution you against dumping more acid in the pool until you can get a TF100. You can compare them here Test Kit Comparison.
    When you're ready to take control of your pool and stop relying on the cheap and unreliable way to test, we'll be here to help you every step of the way.
    While you're waiting on your test kit, here are some really important links in Pool School that you can take a look at:
    ABC's of Pool Water Chemistry
    How to Chlorinate Your Pool
    Chlorine CYA Chart
    Recommended Levels
    Pool Calculator Instructions
    May 2014
    Missouri
    14
    I'm going to go somewhere tomorrow and find a test kit. I will get back to you when I can get more accurate readings.
    38,371
    It is very rare to find one of the recommended FAS-DPD test kits locally ... they generally have no idea what you are talking about or will try to convince you that the DPD is the same, it is NOT!
    May 2014
    Missouri
    14
    Pool looks a little better this morning. Cya is 30-50. Ta looks a little high at 180 or more. Ph looks about 8.4. Fc still 0 tho. Where can I order the test kit and what should I do til it comes?
    amccaul's Avatar
    Apr 2014
    Missouri
    25
    Quote Originally Posted by melissalivengood View Post
    You really need the Taylor T-100 test kit...I fought my pool for one whole year because of cheap test kits. Could have paid for several T-100 kits with wasted money spent on chemicals not needed. Plus when you order the kit you will get amazing support from them on issues with pool.
    Leisure Riviera 34 15k Fiberglass IG; Hayward S180T sand filter; Hayward Super Pump dual speed .75/1.5 HP; Pentair PG-2000 Fiber Optic Lights.
    May 2014
    Missouri
    14
    Do you have a link for it?
    11,969
    The TF test kits sells the TF100. Taylor sells the K-2006.
    http://tftestkits.net/splash-page.html
  20. Back To Top    #20
    May 2014
    Missouri
    14
    Thanks.That kit looks overwhelming. What should i do until this arrives?
