Results 1 to 13 of 13
Thread: Measuring bleach...and testing
    Jul 2012
    Forest, VA
    79
    Ok I have a simple and probably a stupid question. How does everyone measure the amount of liquid bleach you are putting in the pool? If I put in 1 jug....that's easily measurable, however If I am doing an OCLT and SLAM....I need to measure after the sun goes down and figure out how much to bring up to shock level....say its 82 oz.....does everyone just guesstimate 2/3 of a 121oz jug? Is there a clear measuring jug I can purchase? Should I check the FC level again to see what it is after I add the bleach or just go with my estimate? What if I add too much and think my pool is clear of algae? or too little and think I have an algae problem. With the accurate tests that state I can't lose more than 1ppm for the OCLT I feel that I should be adding more exact amounts of bleach. I don't mind the testing but this seems like I am doing something wrong having to test so many times. Thanks in advance for your replies. Still trying to get the hang of this whole pool thing, even though I have owned it for 5 years.
    12,000 gal Octagon vinyl in-ground pool. Hayward S220 sand filter 3/4 hp pump, heat pump heater
    Re: Measuring bleach...and testing
    Measuring by estimate, for example judging 3/4 of a jug by eye, is usually sufficient. You don't need to have it exact. Some people like to use a plastic two quart measuring cup (i.e. a fairly large one), but doing so isn't essential.
    Since you measure and then adjust, any small error in the amount you add will show up in the measurement on the next cycle and be corrected for.
    Jan 2014
    Buckeye AZ
    807
    I just cut an old bleach jug in half, flipped it upside down (cap on the bottom) and measured 32 oz of water into it. Then marked the line. Now I can easily measure 32 oz of bleach. since I'm putting in about 64 oz of 8.25% every other day, it makes it easier than messing with cups..
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Casey's Avatar
    SW PA
    10,438
    I'm so guilty on guesstimates when it comes to bleach additions.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by Casey
    ...Annnnd...I represent the other end of the spectrum with my 2 quart measuring cup.
    At the end of the day, if you have a process that works well for you, stick with it!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    I'm a slob when it comes to dosing. My brother even heckled me about it. He watched me run the whole battery of tests using the speedstir, being super-accurate, and then I just dumped half a gallon of bleach in by eyeball. He doesn;t understand that the target is not as important as the now.
    Casey's Avatar
    SW PA
    10,438
    Quote Originally Posted by BoDarville View Post
    I'd say it works pretty well for me. (shameless photo plugging about to go down in 3.... 2..... 1.......) I warned you!
    I'm right there with ya Richard!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It's ok Bo, I'm right there with you. I want to nail it down to a Cat's whisker and see what happens. Part of it is my pool being new and me wanting to know it well, but I like seeing how close I can get.
    Essential Links:
    Jul 2012
    Herndon, VA
    419
    I have a plastic bucket for mopping that has quart measurement lines.....works great for measuring chlorine doses.
    Similar to this:
    http://www.sears.com/shc/s/p_10153_1...030xMPTLxCPA25
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Jul 2012
    Forest, VA
    79
    Thanks everyone for the insight
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    If that's your pool Casey, it looks great!
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    I see a two part question.
    Dosing is a general measure at my pool, done with a tumbler that is hand scribed with marks. If testing indicates the pony needs 20 ounces of bleach, its poured to something north of 20, might be 24, might be 21.
    Measuring for an OCLT would be done by testing, dosing to just north of the requirement, then testing again in 30 minutes for the start point for the test. That is the only accuracy I would shoot for - the test starting point, not the amount it took to get there.
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    Jan 2012
    'burbs of Augusta, Georgia
    7,336
    I use a big quart sized plastic ice/water drinking pitcher that patients in the hospital are provided. The ounces and mL are all marked and its very handy with a big easy to grip handle and convenient (i.e. free!)
