Thread: Should I be concerned?
    Goontoe's Avatar
    May 2011
    Baton Rouge, Louisiana
    5
    My pool seems to be losing more water than just through evaporation. I've had to add water a few times this week. The weather is turning hotter (I'm in south Louisiana), but it seems odd that I'm adding so much water this early in the summer.
    Then, as I'm doing some inspecting on the liner tonight, I see this:
    It looks like a tear in the seam.
    I'm doing a water level test tonight. I'll check the water level tomorrow morning before the filter system comes on and then again around 6pm which is when I did the leveling tonight. That should tell me how much water is being lost within a 24 hour period.
    Anyway, should I be concerned about this tear? The pool and liner has just made 5 years old.
    Thanks!
    -G
    16 x 32 | 19,200 gallons | sand filter | in-ground | vinyl | pump size & flow rate = TBD
    Jul 2012
    CA
    240
    Re: Should I be concerned?
    Put some food dye or Ph test red dye and see if its slowly gets sucked in.
    Casey's Avatar
    SW PA
    10,428
    Is the ground wet where this *tear* is?
    Seams are a lot more difficult to patch than just a hole. It's almost like once they start, they keep on going. You can try to fix it but don't be surprised if the patch fails. Use 3 patches with the first one covering it. Round the edges of the patch, apply glue and lay it on the hole. Cut the next patch bigger than the 1st patch and repeat the process with the 3rd patch being bigger than the second.
    Goontoe's Avatar
    May 2011
    5
    Thanks for the replies guys. Here is my overnight observation:
    6:00pm - baseline measurement made
    7:30am - level down .5" overnight without pump running
    30,414
    That's a leak. 1/4" to 1/2" (or less) in a 24 hour period is usually evaporation.....yours is a leak.
