Thread: Loose plaster chunks and red tape in light niche. Problem?
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Hi all! It's been a while since I poked my head up here.
    I pulled out my light for the first time, and I noticed what looks like chunks of loose plaster and pieces of red duct tape sitting in the niche.
    Also, the niche was rough with plaster around the inside surfaces (I guess I though it would be smooth on the inside).
    Is this something to worry about? My fear is that this was a patch that was cobbled in there and now that I disturbed it it will start leaking.
    Thanks!
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Aug 2011
    Southern California
    188
    Re: Loose plaster chunks and red tape in light niche. Problem?
    Most likely just remnants from the original plaster job.
    You can use some food coloring to see if it seeps through where the plaster/tape was.
