Thread: Build up base...?
    Apr 2014
    CT
    26
    Build up base...?
    OK... Before anyone yells at me... I know that the rule of thumb is to dig down to the lowest point. I did that. But now my question is that I would like the bottom of the pool closer to level with the higher side... Can I build up using a base with something like 3/4 processed stone, compact that, and then put the pool on top of that? I'd still use the sand and foam bottom.
    I know the concern is for settling... But at that point if there is any settling, it should be uniform.
    Re: Build up base...?
    It is possible to build up a little if you use a material that compacts really well and are through about compacting it. However, it is easy to get this wrong, and if there is any settling it will never be uniform. That is why it is almost always better to dig the high side down further rather than trying to build up the low side.
    Casey's Avatar
    SW PA
    10,463
    You can use the crusher stone and a plate compactor in 3" lifts.
    You tired Bob?
    Apr 2014
    CT
    26
    Casey - I'm not sure if you are sincerely concerned if I am tired from all that digging... or if you being a little bit facetious.
    I had a little bit of help. so the dig wasn't too bad.
    Casey's Avatar
    SW PA
    10,463
    I'm playing with you Bob. I know the hard work that goes into these digs. Believe me when I tell you that I know all about them! I have done atleast 4 digs in the last 7 years!
