Thread: Winter Test down under
    Darko5500's Avatar
    Aug 2013
    Sydney AUS
    17
    Question Winter Test down under
    Hi Guys,
    Results from this morning.
    Ch 290
    Cl 16
    TA ???
    CYA 80
    PH 7.8
    I normally test for PH test twice a week due to running SWG and my PH tends to drift up. However, this morning ran the full test and when I found something funky with my TA. The sample would not go from green to pink, it went from green to yellowish at about 90. Did a second test with same kit k1003 and same result. Tried with K2106 kit and also got same result. The K1003 is about 12 months old and the K2106 is about 7 months. Is it possible that the high Chlorine is bleaching TA? I last ran a full test 2 weeks prior and everything was spot on. My chlorine is high still due a SLAM 2 weeks ago and I have turned chlorination off today to bring levels down. Any ideas on the TA colour?
    Cheers,
    D.
    Pebble 63kL - Waterco S602 (Zeolite) - Hurlcon EVO P300 3 sp 1KW.
    Watermaid SWG QT150 cell - Polaris 280 Cleaner.
    Spa - spill over (no heater at the moment).
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: Winter Test down under
    Normal
    At high FC, the TA tests goes blue> yellow instead of green>pink. The results are still valid.
    Check out the TA notes in Extended Test Kit Directions.
    Darko5500's Avatar
    Aug 2013
    Sydney AUS
    17
    Thanks Richard. Will drop the FC and retest in a couple of days.
