Thread: Foam over sand?
    MermaidMama's Avatar
    Aug 2013
    Pennsylvania
    158
    Foam over sand?
    My pool installer included sand as a base and I do want sand put down on top of the dirt.
    Would the foam or gorilla pad on top be overkill?
    Is it typically one OR the other?
    If gorilla type pad/foam goes over sand, the benefit would be its s softer step? Thinking that might not really matter to me.
    MermaidMama
    18' Round x 52" Doughboy AGP
    Powerline XP Pump 1 HP
    Aquaview 17" Sand Filter
    TF-100 Test Kit
    JUST WAITING ON INSTALL!
    MermaidMama
    18' Round x 52" Doughboy AGP ~ TF-100 Test Kit
    Powerline XP Pump 1.5 HP ~ AquaView 20" Sand Filter ~
    Re: Foam over sand?
    A vermiculite bottom might be your best choice.
    Support the site
    Re: Foam over sand?
    When using foam or a gorilla pad you don't really need anything else as long as the ground is level. Sand is often used to level out the final small unevennesses, but isn't required if everything is already level.
    Aug 2013
    Pennsylvania
    158
    Re: Foam over sand?
    Quote Originally Posted by JamesW View Post
    I'm going to have to google that one.
    Thanks Jason, that makes sense with the sand.
    MermaidMama
    TF-100 Test Kit
    MermaidMama
