Thread: indoor/outdoor pool...need some expert advice!
    Caledon's Avatar
    May 2014
    Caledon, Ontario
    4
    so, my wife and I are looking at a very nice home near Georgian Bay in Ontario. We have had pools for the last 20 years and were excited to see that this place had one...but we have never seen one like it before - its half inside and half outside. I have attached a photo to this post. I am looking for any kind of constructive advice on how to handle this...do we close it in the winter? It is closed now and has had a lot of water drained out (more than I ever would) with an elephant cover outside and no cover inside. The only barrier between indoor and outdoor is a plastic panelled garage style door. There are 15 2x8 sheets of pink Styrofoam insulation on top of the cover...I am guessing this is used somehow under the cover.
    Anyway, if any of you have experience with this sort of installation I would love to hear about it.
    Robert
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: indoor/outdoor pool...need some expert advice!
    Welcome!
    Never seen anything like it. It looks like the set for a James Bond movie!
    Casey's Avatar
    SW PA
    10,422
    That has got to be the craziest pool I've ever laid eyes on. Like... how would you even use the pool in the winter months? I would say you can't because it'd be too cold.
    wbdahenry's Avatar
    May 2013
    Geneva, NY
    8
    I've seen an indoor/outdoor pool like this at a hotel/lodge, The Inn at Holiday Valley, Ellicottville, NY. Apparently, they keep it open all year 'round.
    Geneva, NY, 31,000 gal 18x44 Lazy-L IG vinyl, Pentair SD80 3.5sqft sand filter @75 gpm, Pentair Superflo 1.5HP pump, AquaComfort ACT125 Heat Pump, installed early November 2012, Maytronics Dolphin M-5 Robotic Cleaner
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome!
    That would be a dream pool for me. I have often thought that would be very cool if you could isolate them in seasons. I suppose there isn't such a feature on this one is there?
    Essential Links:
    Caledon's Avatar
    May 2014
    Caledon, Ontario
    4
    Had a better look at it this afternoon. The liner is torn at the bottom of the stair which explains why it was drained so low. But a great idea for a future build...it was a 54" deep on ground with a really nice concrete deck. Those garage doors on both ends opened and the skylight was massive (looked like some roof leaks on the flat roof also). Between the indoor and outdoor sections there is a huge glass panel door that can be opened - on the bottom is a heavy plastic flap that extends down into the water perhaps six inches...that's how the two areas are separated.
    No way this stays open during the winter but it would definitely extend the season up here to April/October!
