Results 1 to 8 of 8
Thread: Drained, replaced water, now what?
    Xtie1111's Avatar
    Sep 2013
    Lowell, indiana
    18
    Last year I bought the tf-100 test kit after my CYA went through the roof and we couldn't control the algae.
    We just filled our pool with fresh water and started the pump. If anyone could help me figure out where to begin I would greatly appreciate it..
    FC=0
    PH=8.2
    TA=180
    CH=50
    CYA=0
    Water is starting to get cloudy but it's clear..
    Where do I begin? I think I need to slam it? But what and how do I adjust things to get to that point?
    15,000, AG, cartridge, pump size to come, 6/1/12
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Drained, replaced water, now what?
    You need to add chlorine to get to 10. You need to add acid to get to about 7.2. You need to add CYA granules in a sock to get to 30 or so.
    Are you starting tonight? I'll assume so.
    If it's looking cloudy, get the chlorine in first. Nip it in the bud! While that's mixing, measure out your CYA and tie it in a sock or nylon and either drop it in the skimmer or dangle it in front of a return, off a pole or something. By the time you're done with that, half an hour should have elapsed. Add the acid. One lap around the pool with the brush to be sure things are well mixed. Go have a drink. Recheck FC. Add what you need to get to 10 again. Leave the pump on the whole time. Test the pH, TA, FC & CC again in the morning. Report back and receive your next instructions.
    For a pool your size, 2 jugs of 8.25% Clorox will get you to 10+
    37 oz of 31.45% acid will lower your pH. You can eyeball a quart and get close enough for now.
    A whole 4 lb canister of CYA will take you to 32. Close enough. No measuring needed!
    Xtie1111's Avatar
    Sep 2013
    Lowell, indiana
    18
    Thank you so much and I will do that. One problem...I only have 1/3 of a 4lb bottle of stabilizer granules left. Can I add that tonight and the rest tomorrow?? (Everything w/in 30 minutes drive is closed now) and if that's okay, I have everything else and am ready to follow your direction thank you again for your help!!
    Richard320's Avatar
    Jan 2010
    19,075
    Sure. You won't be losing any chlorine to the sun overnight!
    Xtie1111's Avatar
    Sep 2013
    Lowell, indiana
    18
    Thank you thank you!!! You don't know how much I appreciate your responses! I'll report tomorrow!
    Xtie1111's Avatar
    Sep 2013
    Lowell, indiana
    18
    Good morning! I did what was recommended and here's my readings...
    FC-5.5
    CC-0.5
    TA-130
    PH-7.2
    Water is not crystal clear but is the color it's supposed to be
    Any input is greatly needed and appreciated!
    Richard320's Avatar
    Jan 2010
    19,075
    Quote Originally Posted by Xtie1111 View Post
    FC-5.5
    CC-0.5
    TA-130
    PH-7.2
    Take FC back up to 10 and brush around to loosen any dead algae clinging to the walls. Keep an eye on the filter pressure. Add the remainder of the CYA. You're SLAMming!
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    I'll start with "add bleach to get FC back up above 10".
    EDIT -- too slow... again
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
