Thread: TF100 kit: Which reagents do you run out the quickest?
    May 2014
    Houston, TX
    155
    Title says it all. R-0870 and R-0871 seem to be the ones I use the most in just 2 days of having this kit. Did I just answer my own question? ha
    IG gunite pool size: 12,500 gallons - includes spa with spillover, Polaris vacuum cleaner, Ultrapure Ozonator, inline tab chlorinator that I no longer use
    Filter: Hayward Swimclear Model #4030, 4-Cartridge Filters
    Pump: Century, 2 HP with a Hayward 6060 booster pump
    Date of build: March-April 2014 *NEW* : Test kit: TF-100
    Re: TF100 kit: Which reagents do you run out the quickest?
    If you test daily with the FAS-DPD test, you should get the XL version of the kit. Other than that, I never run out of anything before two years are up, at which point I replace the whole set.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    That's why there's the XL option! It's for SLAMmers like you.
    I actually blow through the R-0012 pretty fast. When CH starts to approach 4 digits, it takes a lot of drops!
