Thread: Fan problem with Pentair MiniMax pool heater
    May 2014
    bloomington, in
    1
    I have a inground pool with a Pentair MiniMax pool heater installed in 2006. As of a couple of nights ago the heater will not start and I beleive this is because the Fan is not running correctly.
    I beleive the start capacitor may be the issue, but i am not sure. The motor does not always start, but when it does get started by itself or by manually starting it, it does not run at full speed. I get very little airflow and the motor gets quite hot.
    Does this sound like a run capacitor issue?
    other suggestions
    Jul 2012
    CA
    240
    Re: Fan problem with Pentair MiniMax pool heater
    Im having the same issue... Do heaters have run capacitors?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    If you both have a forced draft pool heater, it is likely that the fan motor bearings need to be oiled. Furnace oil would be the thing to use. You may have to remove the fan and disassemble it to oil it.
    @Marty -- You didn't say in your other thread that you have a forced draft heater. The vacuum switch is there to ensure you have airflow through the combustion tubes before the main valve is allowed to open.
