Thread: First time adding borates to my pool
    Apr 2012
    South east VA
    26
    I picked up some muriatic acid next by crown at lowes, http://www.lowes.com/pd_425003-34228...cid&facetInfo=
    And I was wondering if that would be ok to use instead of regular muriatic acid. I picked it up cause of the less fumes and odor statement. Thought I would ask here before adding to my pool, can't seem to find the strength on it. And If I do use it, should I adjust the numbers that poolmath tells me to use? Thanks,
    18' above ground pool - 7500 gallons
    Hayward Aqua-trol SWG
    TF-100 test kit with speedstir
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: First time adding borates to my pool
    It's still muriatic acid, just weaker. 15%
    http://www.packserv.com/products/crown-next/
    Isolated Spa - 345 Gallons
    Apr 2012
    South east VA
    26
    Thanks! So I assume if poolmath calls for one gallon of 31%, I would need to add 2 gallons of 15 percent?
    Yep.
