Thread: Correct pressure for Hayward 4030?
    May 2014
    Houston, TX
    155
    I checked the pressure on my Hayward 4030 filtering system, and it's running at 20 PSI, a little higher than yesterday. Normally it runs at 14-16 PSI. The green needle is set to 14, and the red needle is set at 24, and this was set by the pool builder.
    I looked at the Hawyward manual and it says the ideal pressure is 7-10 psi. Have I been running at a too high psi level all this time? How do I lower the psi? Should I clean the filters again? (I've already cleaned them only 3-4 weeks ago).
    IG gunite pool size: 12,500 gallons - includes spa with spillover, Polaris vacuum cleaner, Ultrapure Ozonator, inline tab chlorinator that I no longer use
    Filter: Hayward Swimclear Model #4030, 4-Cartridge Filters
    Pump: Century, 2 HP with a Hayward 6060 booster pump
    Date of build: March-April 2014 *NEW* : Test kit: TF-100
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Correct pressure for Hayward 4030?
    Pressure varies from system to system. Too many factors to have a "normal" pressure. That green/red needle setting is meaningless as it is now. Well the green one might be correct, but if your "clean" pressure is 14, the red needle should be at 17 or 18. That's a roughly 20% rise in pressure from "clean." It's time to clean the filters.
    I'm less familiar with cartridge filters, so other experts can chime in but I'd read Maintenance and Cleaning of Pool Filters.
    EDIT: Also... if you're having to clean the filters more often than usual or you expect, is there a chemical reason why? Test results wouldn't hurt.
    Isolated Spa - 345 Gallons
    May 2014
    Houston, TX
    155
    Is it normal for the pressure to go up 20% while slamming in order to get rid of organics?
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by yardoasis View Post
    Oh yes, didn't know you were in the process of a SLAM. That's when your filter will rise the most because it is clearing the pool. Cartridges are VERY effective at clearing particulates and will catch alot, especially if you're killing algae. Do you have another thread about your current SLAM?
    EDIT again... I see you do have a SLAM thread. Keep at it and yes, clean the filters.
    May 2014
    Houston, TX
    155
    Problem solved!! Cleaned the filters, got a LOT of gunk out and couldn't believe how much ithe filters picked up in just 1 month and a 4 day SLAM.
    Pressure running at a cool 16 psi (green/red range is 14-24), a solid 4 psi decrease.
    Not one air bubble in the entire system! Pretty darn proud of myself right now
