Thread: Pentair Salt water Cell
    Liteguy's Avatar
    Aug 2011
    Cave Creek, AZ
    49
    Hello,
    Have a Pentair SWC now entering it's 2nd season. The cell builds up calcium and twice a year I clean it out per Pentair's instructions. The issue is I cannot seem to keep FC levels up and am shocking the pool once a week now to keep the algae bloom from going crazy. The salt level reading is 3500PPM. All the lights are green on the SWC and have the setting to 100%. Any ideas? Is there a way to truly test these? Thanks in advance...
    Steve-Liteguy
    13K Pebble-tech Pool, ECO pump, IntelliChlor SWG, DE
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    Re: Pentair Salt water Cell
    Hrm....do you have a current full set of test results? Specifically, what's your CYA level?
    25000 gal in ground plaster. '79 vintage. Cartridge filter.
    Jun 2011
    Long Beach, CA
    2,781
    Once algae takes over, a SWG can not kill the algae fast enough and the pool needs to go through the SLAM process.
