Thread: Light fixture pop out and has water inside
    May 2014
    Tallahassee, FL
    1
    Is it possible to pull out the light fixture and cord from the junction box and leave the hole / house / niche empty and will it be safe to do so and will it made it difficult to put new fixture back in when replacing the liner? This is my first post. Thanks in advance.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Re: Light fixture pop out and has water inside
    Hi,
    Welcome to TFP.
    Actually the fixture itself is mounted into a thing called a Light Niche. The Nitche is fixed to the pool wall. On the back of the light nich is a conduit fitting and the conduit for the light cord goes through that fitting, thru the conduit and to the switch.
    Disconnec the cord from teh light switc, remove the light fixture from the Nice and then take the whole thing out.
    Not a problem to do at all. Do just the reverse to put it back in when the new liner is installed.
    Edit: Tip. WHen you disconnect the light cable from teh switch, use some electrical tape and tape a pull string to the cable. The use the string to pull the cable back to the swtich when you upt the light back in.
    hope this helps,
    Divin Dave,
    30,432
    How long is the pull from the niche to the junction box? Are there other wires inside the conduit?
