Thread: Removing metals from fill water
    Cary, IL
    29
    I recall a post from Ben on PoolSolutions where he talked about a method to remove metals from fill water. I believe he said to load up one of your skimmer baskets with chlorine pucks and fill directly through the pucks. From what I recall, I believe he said the high chlorine concentration in the skimmer basket would cause the metals to precipitate out of the water as the fill water passed through the pucks and would then be removed as the water passed through your filter.
    My fill water (well) has extremely high levels of iron and I am wondering if anyone can confirm whether or not this process may help to eliminate most of the iron.
    Thanks in advance!
    Bill
    Bill Boehm
    Cary, IL
    40,000 Gal, 20x40 IG Liner with water slide and swim out. Auto-cover, Polaris 280, Pentair (Sta-Rite) VS-3050 pump with EasyTouch Control System and Laars LG250N Heater.
    Guest
    Re: Removing metals from fill water
    Here is the thread that PoolDoc discusses what to do. It uses Cal Hypo, not trichlor.
    http://www.poolforum.com/pf2/showthread.php?t=865
    Here is a thread where he discusses copper staining and how to get it out that might also be of interest:
    http://www.poolforum.com/pf2/showthread.php?t=274
    Cary, IL
    29
    Thanks for digging it up Waterbear!!
    Bill Boehm
    Cary, IL
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Another option might be the filters sold by one of the pool catalog places. I think it's In The Swim. You just use it on the hose while filling. No experience, but I'd try it if I had the problem.
