Thread: Crack in pool stairs... do i need to fix it?
    Mar 2014
    Fort Worth, TX
    24
    Hey Guys!
    While draining the pool (CYA is too high) i noticed a crack in one of the stairs. Do I need to fix this crack? And if so, what's the best procedure?
    (also... the pool walls look kinda blotchy. Do I need to do an acid wash or just live with it is the best way?)
    Thanks for your expertise,
    --Lee
    25,000 Gallon Pool, In Ground, Plaster, DE Filter (need to get model), need to get pump, pool build year unknown
    Casey's Avatar
    SW PA
    10,448
    Re: Crack in pool stairs... do i need to fix it?
    Hey Lee. Again, Welcome to TFP!
    Question for ya... Are or were you losing any water before the drain/refill? If not, it could just be a surface crack but I'd keep an eye on it. It looks pretty scary huh? I'm sure some others will comment soon too.
    Mar 2014
    Fort Worth, TX
    24
    Thanks for responding. Nope, I haven't noticed any water loss.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    I would consider repairing it now while you have the water line below the crack. There are products that you can work with below the water level, but they do an iffy job.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    My vote is for fixing it while hte water is out before it presents a problem in the future.
    If you could post some pics of those blotches you mention, you probably could get some pretty good advice on what to do about them.
    Divin Dave,
