Thread: chemical/ electrical question burnt pump
    May 2014
    Gaffney, SC
    16
    My water level finally got to the proper level last night, CYA put in yesterday afternoon, bleach last night and then the pump died. I was running a 100ft uf 12-2 to a gfi that the pump was plugged into, 20 amp breaker. Pump got extremely hot and shut off. After cool down I restarted the pump and it ran for a couple seconds and shut off, with a wisp of smoke from the pump. It is a 12 amp 115 volt pump. Not sure if it could have been caused by voltage drop as the pump manual says to use 10 gauge wire for runs 50 - 100 ft to prevent voltage drop from damaging the pump. The pool store says the will replace but will take untill tuesday. So my second question is can I still add my daily bleach without the pump running, and is it ok for the CYA to still be dissolving without any circulation?
    I also need to add Borax and Baking Soda.
    How bad of a situation am I in?
    Thanks in advance
    13.5 k gallon, AG Swim n' Play Inc. Islamorda 24 ft. round , Pentair Dynamo 1.5 HP Pump, Pentair Sand Dollar SD40 sand filter 40GPM.
    Install 5/20/14
    Re: chemical/ electrical question burnt pump
    You are going to need to put in some extra effort to make up for the pump being out, but you should be able to get by.
    Add chemicals in the early evening, after the sun is off the pool. For solid chemicals, pre-dissolve them in a bucket first. Pour slowly while walking around the pool, and right after adding brush the entire pool to mix it into the water.
    The CYA won't continue dissolving, but as long as it is either in a sock or the filter it won't hurt anything either.
    May 2014
    Gaffney, SC
    16
    Quote Originally Posted by JasonLion View Post
    Thanks I got ok'd to drive to nearby city to pick a new one up, so maybe I'll be able to get it in today.
    Hope somebody chimes in on the 12-2 or 10-2 for 100 ft run.
    Install 5/20/14
    Apr 2014
    Kentucky
    3
    Quote Originally Posted by cosmic charlie View Post
    Based on your specs of 12A, your voltage drop should only be about 3.5%, which is a little high - especially if your panel voltage is on the lowside. I would have followed the manufacturer's recommendations on that one.
    FWIW, motors operate as constant power devices, meaning if the voltage is low, the current in the windings will increase to compensate. High current results in increased heat, breakdown of dielectric, and eventual failure.
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    ^^^^^+1 to the response from Crionics
    Manufacturer gives you the answer. If you can, check voltage as is at pump. Resistance of the 12/2 is probably got you somewhere below 109v. Not a good set up for constant load.
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
