Thread: Starting % and run time
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    I have a friend with a 10k gallon AGP and a Compupool 16 SWG. What would be the suggested operating percentage and run time to start to dial it in? Texas pool with 70% full daily sun.
    Re: Starting % and run time
    Start the SWG at 50% and adjust from there.
    For pump runtime, more information about pool size vs pump size would help, but starting at four hours is good for many pools.
    Oct 2013
    Chapin, SC
    1,141
    Water temp is also a good indicator. My water temp is in the mid 80s now and My FC is barely keeping up with the loss during the day. I'm running 80% for 8 hrs now and plan to increase my run time to 12 hrs for the time we're going to be away.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Apr 2010
    East Texas
    9,572
    Thanks guys.
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    use poolmath
    http://www.troublefreepool.com/calc.html
    enter voluum of pool in metric (38,000 litres)
    at bottom of poolmath use effect of adding chemicals
    choose chlorine gas and change quantity to 16g as you are dealing with a 16g cell
    will give you 0.4ppm free chlorine per hour at 100%
    i would start at 6 hours at 100% for 2.4ppm fc and adjust from there
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
