Thread: Gone for a couple days -- can I jack up chlorine to compensate?
    Mar 2014
    Central Flordia
    67
    We are leaving to go out of town today and come back Monday. This is my first pool and also my first absence from it. I will be able to balance the pool this afternoon but won't be able to again until Monday. My chlorine target is generally 5ppm and I lose maybe 2ppm a day. Can I put enough chlorine in today to bring it up to ~9-10ppm to last over the weekend? My daughter and her grand mother will still be around, can they safely go swimming in this level of chlorine without bleaching swimsuits, etc.?
    For that matter, both my wife and I will be gone for an entire week this summer. I'm guessing I can't jack up the chlorine to ~16ppm to compensate for that week, can I?
    ~16,200 gallon 18x34 Doughboy AG pool. Fully above ground (not buried, no deep end). TF-100 test kit. Variable speed pump. Cartridge filter.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Gone for a couple days -- can I jack up chlorine to compensate?
    Can you get a floater and put some tablets in it? The chlorine won't last through the weekend. That level is not going to bleach anything out (unless one had that level with 0 CYA).
    Smykowski's Avatar
    Sep 2011
    3,065
    What's your CYA level?
    You can safely bring the FC up to SLAM level, and as long as it's below SLAM level, it's safe to swim in. When I go on vacation, I raise FC to SLAM and put the solar blanket on it. No problems for a week.
    Can you trust Grandma to pour bleach in the pool once while you're gone? If you showed her exactly how to do it, exactly how much, and exactly when to do it?
    Butterfly's Avatar
    South Carolina
    10,045
    You can do a site search for "vacation" and get lots of info/ideas
    You're done SLAMing when:
    Mar 2014
    Central Flordia
    67
    Pool isn't two weeks old yet, my CYA level a week after adding my first dose was 30. I added another 15ppm this past Monday in a second dose to hopefully bring it up to 45ppm. Looking at the chart, SLAM level is between 16-20 for 40-50CYA.
    I thought floater tablets were a bad idea? And why wouldn't the chlorine last, does it use up more a day with more chlorine in it or something?
    I could maybe trust her and I suppose I could even make it easier for her and just tell her to add X amount of bleach on Sunday without testing, assuming X wouldn't raise it past SLAM level. Although she sometimes has troubles getting around and forgets things, so if it's safe and doable I'd rather just jack it up today.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Floaters are ok as long as you know your CYA level. If you are in the recommended range it is ok to use 1 or 2 pucks while you are away from the pool. You can't do it all the time or the CYA will be out of control in a big hurry!
    Love TFP? Become a
    TFP Supporter!
