Page 1 of 3 123 LastLast
Results 1 to 20 of 60
Thread: First time pool build - The Woodlands, TX
    May 2014
    The Woodlands, TX
    48
    New to the forums, but thought I'd post a thread to track my progress as we get our pool built. Went with a local PB who designed a freeform pool w/ spa that is 35'x18'. Following is a list of all the equipment listed on the contract:
    Pentair Clean and Clear 420
    Pentair Intelliflo 3.2VF
    Pentair 320cl Chlorinator
    Pentair Master Temp
    Pentair Easy Touch 4
    Pentair Screenlogic
    2 Pentair 250w pool lights
    1 Pentair 100w spa light
    Maytronics M4 cleaner
    Silencer 1.5hp
    Any problems so far? We really had very little input into the equipment, as we knew nothing about pools, but since since I've been reading up and it seems Pentair is pretty well respected.
    Our dig was yesterday, and after being told they would start around 7-8am, we got a call late the night before saying that they would actually be doing our dig second in the day. I was a bit worried when they didn't show up until 2:30, but they got everything dug before dark. The crew was pretty cool about answering some of my random questions, and even used the Bobcat to deliver dirt to my front yard and even smoothed it out for us in a section where I was trying to raise and level the yard.
    Later last night we ran into our first crisis. We've added on a utility room and a bathroom to the rear of the house that connected a once detached garage to the house. Turns out the sewer line for the washer and the bathroom runs directly into the new hole in your backyard, and no one mentioned to me that they ripped out the pipe headed to the septic system. When I started looking more, I found that the pipe running from our guest house across the yard to the septic tanks got ripped up too. In the process of figuring out how to get this plumbed back in, and if it's worth it to run temporary lines. We are already having to rip out the aerobic septic system in the back yard and move it to a drip system in the front, but that crew isn't available for a week or two.
    One question - What is the best image host to use for pictures? I have some to post, but haven't posted a picture in a forum in probably 5+ years.
    [Under Construction] ~22.4k Gallons - 35x18 freeform IG Gunite w/ 6" raised freeform spa - Pentair Clean and Clear 420, Intelliflo 3.2VF, 320cl, Master Temp heater, Easy Touch 4/Screenlogic, Maytronics M4
    Decking and plaster still undetermined. - Contract Signed 5/10/14 - Excavation 5/23/14 - Steel 5/24/14 - Stub Out 5/24/14 - Gunite 5/30/14 - Plumbing 6/3-6/4/14 - Electrical 6/5/14
    Feb 2013
    Cypress, Tx
    71
    Re: First time pool build - The Woodlands, TX
    Good start, Eric. who is your PB?
    Easiest way to post would be to use your smartphone and have this app called Tapatalk on it, if you are used to taking pics on your smartphone.
    But as I posted, iPhone does not get the best pics..;-(
    Other way would be here -
    http://www.troublefreepool.com/threa...h-screenshots)
    My pool build - http://www.troublefreepool.com/threa...on-we-got-Pool
    20,000 Gallons IG pool with spa, , 117 linear sq ft, Pebble Fusion.
    Hayward 4030 cartridge filter. June '14. TF-100, Polaris 280.
    Cypress, TX.
    Jan 2013
    Houston, TX
    1,079
    Are you actually in the woodlands or just outside the woodlands (ie Creighton Ridge)? I ask because of the septic system...
    Tapatalk works like a champ for posting pictures....
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    May 2014
    The Woodlands, TX
    48
    This was entirely filled with brush from the wooded lot next to us. It took the crew about 10 minutes with the bobcat to clear a part and take out a small section of the fence.
    The first scoop!
    After about 2.5 hours.
    Excavation is done in about 5 hours!
    The remains of the sewer pipe.
    Steel crew showed up at 630am. This is 2 hours later.
    Our pool builder is Ultimate Pools. I texted him at 630 this morning and he called me back almost immediately. I told him we had a crappy situation, so he is headed over this morning to help me figure it out.
    Quote Originally Posted by karmabiker View Post
    We are actually in Conroe, just outside of the woodlands off of 1488 and 242. It just feels a lot more like the woodlands than it does conroe here I suppose.
    I was quite impressed with Tapatalk. Made my first picture post pretty easy.
    Jan 2013
    Houston, TX
    1,079
    Chuckle ... crappy situation... good one.
    Cool - Carriage Hills area. It's nice out there. My parents live in Conroe (Creighton Ridge - just north and east of you), I grew up in spring and lived just south of the woodlands in Auburn Lakes until 4 years ago. Now down in the Garden Oaks area.
    Good luck with the build - do you know what kind of startup your builder is planning to do? What kind of surface do you have planned?
    You may want to consider LED lighting. It will cost a little up front but the lack of maintenance is a winner, they do cost less to operate as well however given the usual runtimes there isn't a case for ROI (though it would be nice to run the pool lights all night without guilt).
    --Chris
    May 2014
    The Woodlands, TX
    48
    We actually haven't talked about startup yet. When we started this process I had no idea of how pools worked, but I'm here trying to learn as much as I can before the pool is done.
    As for the finish, it will be one of the matrix pebble finishes, but we haven't picked it out yet. Decking will probably be stamped concrete with a cantilever edge, but that's not for sure either. The current contract is actually flagstone coping with salted concrete deck, but we aren't huge fans of the salted concrete.
    May 2014
    The Woodlands, TX
    48
    The pro bono landscaping work in our front yard. It was in bad shape, very sunken and not level at all. This should be a big improvement.
    Anyone have opinions on lighting? Currently debating whether or not to upgrade from regular white lights to the Intellibrite 5g color LEDs. We already have all the Pentair automation stuff, so would the $1400 for the upgraded lights be worth it?
    Edit - Pool builder offering the Globrite LEDs as an upgrade over the Intellibrites. I was under the impression that Intellibrite was the top of the line. Am I wrong?
    Jan 2013
    Houston, TX
    1,079
    Glowbrites are smaller with less output.
    I would go intellibrite. I think the globrite is designed for shelves and shallow locations.
    Edit:
    Here you go:
    http://www.troublefreepool.com/threa...tair-Lighting)
    May 2014
    The Woodlands, TX
    48
    That's what I thought. He was offering 2 intellibrites in the pool and 1 in the spa for $1425, or 3 and 1 for globrites for $1650. I just got off the phone with him, and told him I wanted the Intellibrites. I hope it turns out looking like all the pictures I've seen. They seem like a really neat thing to play with.
    Jan 2013
    Houston, TX
    1,079
    When you get ready to look at chlorination Napco on 2920 sells CL in bulk in a 15 gal carboy. That and a stenner pump will make life very very easy (don't confuse your pool builder with this). Make sure there is an extra 110v outlet at your pool pad to plug the stenner into later.
    If you have time take a good read on pool school (big link upper right ).
    ... and order your TF-100 test kit now... with the XL option to get you through the start up.
    May 2014
    The Woodlands, TX
    48
    I've been reading the Pool School stuff as I've had time, and am actually excited about how simple pool care can be.
    What's a stenner pump? I'm really hoping you are going to tell me that it's a way that I can automate the liquid bleach.
    Jan 2013
    Houston, TX
    1,079
    Quote Originally Posted by eric281 View Post
    What's a stenner pump? I'm really hoping you going to tell me that it's a way that I can automate the liquid bleach.
    Give that man a prize. It is. Its a hike but if you want to take a look a a setup let me know - you are more than welcome to swing by (Shepherd / 43rd area). More than happy to walk you through all of the ins and outs.
    Pictures shortly.
    Jan 2013
    Houston, TX
    1,079
    Stenner
    Tank
    Injection point
    May 2014
    The Woodlands, TX
    48
    That seems really cool. Is it on a timer or something?
    Jan 2013
    Houston, TX
    1,079
    It is, I have the high capacity stenner and run it on a timer independent of the motor. Total time varies through the year from 15 min run time in the winter to between 1 and 2 hours during the summer depending on water temp and where my CYA is. Mine fluctuates more than most because I am dealing with a calcium scale issue from the former owners. I harvest rain water (off the roof from the downspouts) to try to keep the CH low and pull the scale back into solution. Net result of that is I keep a close eye on my CYA as it actually tends to get a bit low due to rainwater dilution.
    May 2014
    The Woodlands, TX
    48
    Went outside at 12:30 and the steel guys had finished and left. Here are some pictures:
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    Lookin Good Eric!
    good choice on the LED's over incandescent. Not only to the bulbs last tons longer and the light bill is lower.... but LED's dont attract nearrr as many bugs that swarm around it at night !!!
    Divin Dave,
    May 2014
    The Woodlands, TX
    48
    Quote Originally Posted by Divin Dave View Post
    Lookin Good Eric!
    You just made my day with that. I hadn't heard that before. With the wooded lot next door, we seem to get more than our share of bugs around here as it is. I've actually been meaning to look into backyard mosquito control stuff to figure out what the best way to keep the back yard clear for the kids.
    May 2014
    The Woodlands, TX
    48
    Plumbing crew came by and did the stub out, so we are all ready for gunite on Tuesday. Hopefully the weather will hold, but I doubt it.
  20. Back To Top    #20
    May 2014
    The Woodlands, TX
    48
    Plumbers finished 3 hours ago, but they are still here.
