Results 1 to 8 of 8
Thread: Humming Pump
    Jul 2011
    Brookfield, WI
    131
    Humming Pump
    Hi everyone,
    Yesterday I put the krippy krauler (sp?) to run and all was fine and well. A frog took a dive into the pool and there it stays. Me and the children spent some time outside and all was fine and well, except the frog was nowhere to be seen. We needed to go out and upon return I notice the pump was not running. It had tripped the breaker, and it was rather hot. The frog was in the basket and the pump was still on but not running. I turned it off, fixed the breaker and gave it a moment. When I tried to turn it on, it just hummed and nothing, I did not wait, just turned it off and it has been off since. Did the frog manage to burn the pump? Is there a way for me to check the pump before cashing out to replace it?
    20 x 44 in-ground vinyl
    Hayward Pro-Series High-rate sand filter (S310T)
    Nature2 Zodiac chlorinator
    patrick3229's Avatar
    Feb 2012
    258
    Re: Humming Pump
    Hi Brasilmom typically when a pool pump motor is just humming it is do to a bad capacitor. You can purchase a motor capictor for roughly $30 also here is a good guide with video walking you through how to do the replacement http://www.inyopools.com/HowToPage/h...capacitor.aspx
    Jul 2011
    Brookfield, WI
    131
    Re: Humming Pump
    Quote Originally Posted by patrick3229 View Post
    Thank you patrick3229. My husband is going to stop at the local pool place this afternoon and get the capacitor. We were able to open the pump and noticed that the impeller appear to be free. But, interesting enough, it has a cover of sort, but we were not able to get that one off. The little impeller appears to be housed inside said "cover". Will update later once we have the parts and time to work with it more.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Humming Pump
    What kind of pump do you have?
    Jul 2011
    Brookfield, WI
    131
    Re: Humming Pump
    I have a Hayward NorthStar 1hp.
    Feb 2012
    258
    Re: Humming Pump
    If you wanted to replace the entire motor than The replacement motor for the Hayward northstar would be a USN1102 or a SN1102 the USN1102 is if you have an uprated motor which typically has a service factor listed as SF on your motor label of 1.1 SF. If your label reads a SF of 1.65 then you would require the full rate SN1102 motor.
    Jul 2011
    Brookfield, WI
    131
    Re: Humming Pump
    Thank you everyone for the help. The capacitor was replaced and the pump is now running. We took the time to clean the pump up and everything.
    Feb 2012
    258
    Re: Humming Pump
    Awesome!
    Thank You
    Patrick
    www.inyopools.com
