Thread: checking in with a test result
    shaffe43's Avatar
    Mar 2014
    Pittsburgh
    52
    hey all getting the pool ready for this weekend. its been covered since the conclusion great algea war of '14.
    water looks great!! been checkin FC and CC every few days and its been great.
    I just wanted to post my numbers to make sure everything was copacetic.
    CYA - 40 (target 30 to 50)
    FC - 6.5 (target 6)
    CC - 0.5 (target 0)
    TA - 90 (target 90)
    ph - 7.2 (target 7.4???)
    ch - NA
    everything is great except the ph. it says to add like 8lbs of borax. the ph is so close and ill have a ton of people in the pool this weekend is it ok to leave it?
    I was also going to bump the FC up to 10 or so just as a preventive measure.
    also do all the targets seem good?
    manual bleach vinyl liner etc.
    thanks all and once the aquabot is done cleaning her up ima post so sweet pics!
    In Ground 35k Gallon
    36 Sq Ft Nautilus NS DE Filter
    Location Pittsburgh PA
    Aquabot Turbo T2 Cleaner
    Vinyl Liner (new in 2016)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: checking in with a test result
    pH will rise when people start splashing. Leave it alone. The CC should burn off with the cover off and sunlight on it. Yes, raise FC before the mob hits.
    Butterfly's Avatar
    South Carolina
    10,045
    copacetic
    Haven't heard that in a long time
    Your #'s look good. +1 on Richard's comments.
    Have a fun and safe weekend
    You're done SLAMing when:
    30,432
    Butterfly and I were thinking the same thing....copacetic hasn't been around for a while.
    Dobie Gillis? Later than that? I can't remember exactly but I would hazard a guess that you don't twitter, tweet or maybe even text??? Me neither!
    Your numbers are great. Enjoy the swim season!.
    shaffe43's Avatar
    Mar 2014
    Pittsburgh
    52
    haha thanks guys for everything! !
