Thread: Polaris 360 gets stuck in shallow end walls
    Jun 2013
    Phenix City, Alabama
    25
    Hey guys,
    Like my title states, I just purchased a Polaris 360 for my pool. My pool specs are as follows:
    16'x32'
    Figure 8
    3ft shallow end
    8.5ft deep end
    Approximately 20,000 gallons
    Waterco 1HP Pump
    Hayward S200 Sand Filter
    My Polaris 360 works fine, except for the fact that it gets on the walls of the shallow end. When the backup valve engages, it returns back to the deep end, then it returns to the shallow end and gets stuck again. Is this normal for the 360? I have added the included restrictor, and even put in a plug on my shallow end return jet (Only two return jets), checked all hose fittings, etc., and the most RPMs I can get is 25. Any ideas, suggestions would be greatly appreciated on why it keeps getting stuck on the shallow end walls. Thanks guys!!
    Casey's Avatar
    SW PA
    10,428
    Re: Polaris 360 gets stuck in shallow end walls
    Apr 2009
    Toronto, Canada
    33
    I thought restrictor is supposed to reduce RPMs. I would start by removing it and checking RPMs to get it up to 28-32.
    Sorry, I cannot help any more as I have exactly the same issue with my Polaris, but mine is at 32 RPMs, jet is at 11 o'clock and float all the way in - it still cannot clime 90 degree walls. Would love to see more responses.
    16K gallons Vinyl Inground with spill-over spa. 1.5 hp Pentair UltraFlow, 26" Pentair Meteor sand filter, Raypak Gas heater.
    Apr 2009
    Toronto, Canada
    33
    Problem fixed Attach/tape some weight at the back of the float. Takes time to get the weight right, but fixes the issue. The problem is that the back of your cleaner is too light (or rear jet is too weak) and you need to somehow push the back of 360 down (or nose up) - still need to figure out why my particular cleaner is doing that...
