Thread: Leaking Waterfall Help?
    Nov 2013
    Phoenix, AZ
    15
    Question Leaking Waterfall Help?
    Hello. Total newbie here. I've never owned a pool before. I bought this house about 6 months ago and, thanks to this site, I've rid the pool of the algae. So thanks for that.
    Now for today's problem. The pool has a large waterfall feature and it is leaking water out of it at a pretty alarming rate.
    I've tried to use "Waterplug" at the recommendation of my pool guy/advisor but, I can't seem to get it up into the tight spots. And that stuff sets so fast that it's hard to get to the spots quick enough.
    Is there anything on the market like a spray sealant?
    Here's some photos.
    Chris
    50,000 gallon, IG, pebble, Triton II sand filter, Hayward EchoStar VS pump, Dolphin M5
    Casey's Avatar
    SW PA
    10,438
    Re: Leaking Waterfall Help?
    Hopefully someone can help you.
    Oct 2013
    Phoenix area
    91
    There is some stuff the plumbers call "Monkey poop/****".
    I used it on my patio fountain as a sealant around the drain plug. It works awesome!!
    It's hard to find but I found it at my local ace hardware behind a glass case in electrical.
    It's black and soft and comes in a brick shape - kinda like C4! It's wrapped in white plastic.
    Hope this helps.
    13,000 gallon IG
    PCC IG cleaning system
    Pentair equip.
    Attached spa
    Dire need for surface refinish!
    There are sprays available too, but I'm not sure how long they will last. They sell a clear urethane type spray, there's even one sold on tv. It's from the same people that turn a screen door into a boat. Trying to plug a leak where it is coming out is tougher than plugging it where it is flowing in. The pictures seem to show where the water is leaking out. Can you see anywhere the water might be coming from? I would try to seal the areas the water is supposed to flow over.
    DIY 28x38x18 Full L, 26,000 gallons, Pentair VS Pump, SWG, CCP 420 Filter, Sta-Rite Max-E-Therm SR400HD Heater, EasyTouch Controller
    Nov 2013
    Phoenix, AZ
    15
    Thanks everyone.
    I am trying to plug it where it's coming from. The pictures just showed where it's going.
    I'll try some of your recommendations. Today's a bust though. I'm drinking beers in the pool
