Results 1 to 10 of 10
Thread: Help
    May 2014
    Corona, CA
    8
    Help
    Hello everyone, I am new here and have been using the pool school to "school" myself on all things pool (new home/pool owner). When we purchased our home, we knew that the pool needed pretty decent repairs. The pool is usable but skimmer is not due to cracks in the coping in that spot causing leakage. We recently started having an algae problem due to not existent chlorine levels. We are currently in the process of a 36 hour shock session. We added algaecide and shock treatment, ran pump for 12 hours. Another shock treatment this morning and another 12 hours with pump running. I have one more dose to go but this morning my filter was showing 30psi. Max for my filter is 50 psi (per the manual) but should I shut it all down and backwash or am I OK to finish pool treatment? I have about 16 hours to go. I need the algae gone and chlorine level up but I also need a working filter.
    Help.
    12k gal, IG plaster, Hayward 2hp pump (unsure of model), Pentair/Purex SMBW 2048 Filter, built approx 1989, Teledyne Laars Heater, attached spa.
    Aug 2010
    Dallas, TX
    4,052
    Re: Help
    Welcome to TFP! Glad you found us!
    You are following pool store advice. So now you have to decide whether to continue that, or to follow the advice here. The two don't mix.
    You are going to need a GOOD test kit to go through the SLAM process. It is a little different than what the pool store calls shock, because it uses science instead of guess. If you read up in Pool School, you'll find everything you need there.
    For your test kit, I recommend you get the TF-100 from tftestkits.net. Amazing kit.
    May 2014
    Corona, CA
    8
    Re: Help
    I have a test kit but unfortunately I purchased it before I found all of you fine people here. It tests for FC, CC, TA, pH & Acid Demand. Does not test for CYA or CH. As for the test that I had done on my water here is where I am at. Forgive me on missing info, I am going off of memory.
    FC-0, CC-0, TA-120, CYA-100, CH-200, TDS-1400, pH-8.0, Phosphates-50. I'm more concerned about my filter failing due to the high pressure. I think I need to see where my chlorine level is tonight when I get home to determine if the 3rd dose of shock is even necessary.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: Help
    As a general rule of thumb you want to clean your filter when pressure is 25% above its clean filter pressure.
    If those test results can be trusted (pool stores are notoriously incorrect, particularly on CYA), your CYA is too high for easily managing your chlorine.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    30,426
    Re: Help
    That won't be a problem. Your pump cannot produce enough pressure to damage your filter.....it's designed that way.
    Your sequence should be to get your equipment running correctly first and then work on your pool water chemistry (algae) when you are able to operate the equipment properly.
    May 2014
    Corona, CA
    8
    Re: Help
    Filter seemed to be working just fine when I started but pressure shot up yesterday morning. Everything was fine when I got home last night. Water is clear and free of algae now. =) Now I get to tackle the fun task of cleaning the filter. As I had stated before, we are the new homeowners so I do not know the last time it was actually cleaned out. Thinks it s bad idea to try and fully clean it myself?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Help
    Quote Originally Posted by Erin Carpenter View Post
    Nope, it's a good idea. Then you will know what the clean pressure is for sure.
    Hopefully, you don't discover what this person did: http://www.troublefreepool.com/threa...E-filter!-Help!
    May 2014
    Corona, CA
    8
    Re: Help
    Holy ****! I really hope I do not find that when I open it up.
    Do I backwash first, then open it up? Or can I just release the pressure and pop the top?
    Richard320's Avatar
    Jan 2010
    19,037
    Re: Help
    Either way. http://www.troublefreepool.com/threa...aning-Tutorial
    Wear long sleeves so you don't end up with fiberglass itch.
    May 2014
    Corona, CA
    8
    Re: Help
    I read the tutorial and I think I will just take it apart first rather then back-washing first. I don't really have good means of directing all that dirty water into a safe place. My city does not allow pool filter media to go anywhere but the sewer and my clean out is too far away from the pad. This way I can clean it off and put into the garbage.
