Thread: Hayward 1.5 HP 2 speed gallons per hour?
    Jun 2013
    Newcastle, Oklahoma
    508
    cant seem to find a flow rate for the Hayward 1.5 hp 2 speed. This is the pump im having installed with my new pool this weekend. Wanting a flow rate to determine run time.
    anyone know what the flow rate usually is?
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Hayward 1.5 HP 2 speed gallons per hour?
    Which model pump Hayward makes a number of 1.5 HP 2 speeds
    Ike
    p.s. we generally find optimal run time is best found through experimentation since there is no magic one size fits all gallons per hour or turns per day
    mas985's Avatar
    Pleasanton, CA
    11,737
    Flow rate is mostly irrelevant to run time. Read this:
    http://www.troublefreepool.com/conte...-pump-run-time
    Mark
    Jun 2013
    Newcastle, Oklahoma
    508
    thanks fellas
    Jun 2013
    East TN
    309
    I measured mine with a 5 gallon bucket with a 3 or 4 gallon mark in it. Filled it to the line and timed it. It is very difficult to do especially on high. Take several times and average. That will get you in the ballpark somewhere of what it puts out.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
