Results 1 to 13 of 13
Thread: New Pool....have questions
    Jun 2013
    Kansas
    29
    Hi...just set up a new Intex ultra frame pool 16x48....have read through pool school and need to add stabilizer to raise the CYA...so I think I need a wall mounted skimmer basket to add the stabilizer? also, I am considering buying a Krystal Clear saltwater system. Feedback on this?
    Thanks, Kim
    BBB method
    16X48 Intex
    Ultra frame
    Factory Pump
    Re: New Pool....have questions
    You can hang the sock in front of a return with a pole and string.
    Jun 2013
    Kansas
    29
    Thank you!
    Thanks, Kim
    BBB method
    16X48 Intex
    Ultra frame
    Factory Pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Like this, somehow. It doesn't even have to be pretty.
    Jun 2013
    Newcastle, Oklahoma
    508
    kim, tie it with a cord to you intex frame in front of the return. thats how I do mine. and squeeze it everytime you see it, it will dissolve much faster. the faster you get your CYA, the better.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Jun 2013
    Kansas
    29
    okay done...any opinions on the SWG?
    Thanks, Kim
    BBB method
    16X48 Intex
    Ultra frame
    Factory Pump
    Jun 2013
    Kansas
    29
    okay now that the stabilizer is entering the pool via the sock...go ahead and add bleach this evening...tested Zero chlorine ..PH 7.2. I know I need to add bleach, just not sure when?
    Thanks, Kim
    BBB method
    16X48 Intex
    Ultra frame
    Factory Pump
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by Kim1965 View Post
    now. add it right now. you dont have to wait for stabilizer to dissolve, and in fact if you do, then you will have green water as it can take up to a week. Go out right now and add your bleach. tomorrow at same time, test and add bleach as calculated by pool calc. keep your FC at 3 ppm or more.
    until your stabilizer dissolves to where you can test, put in 0 for CYA. BTW, your pool is 6000 gallons.
    http://www.poolcalculator.com/
    30,426
    Actually, we assume the CYA is in your pool and active as soon as you put it in. So the value you should use for CYA is whatever you calculated it would ultimately be.
    Jun 2013
    Kansas
    29
    It tells me to not change the filter for a week after I start adding the stabilizer. The cotton fluff is really clogging the filter...should I change it or leave it be?
    Thanks, Kim
    BBB method
    16X48 Intex
    Ultra frame
    Factory Pump
    30,426
    Since you have tied your CYA off with a sock, it is fine to backwash. Has your psi gone up 25% or more from it's clean pressure?
    Jun 2013
    Kansas
    29
    I apologize in advance...the pump doesn't have a gauge? we just have the type A filters to change?
    Thanks, Kim
    BBB method
    16X48 Intex
    Ultra frame
    Factory Pump
    30,426
    Still OK to clean the filters. Go for it!
