Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: Robotic Pool Cleaner $300 Budget
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Which do you recommend? I checked eBay and they have few of them. Which one is best?
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Robotic Pool Cleaner $300 Budget
    Have you considered a suction side "crawley" type? I'm not a fan of 'robot' vacuums. Too many parts inside that go bad and break.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I'm sorry to be blunt, but to be honest and not pull the wool over your eyes, you just won't get much Robot for 300 dollars. A good friend gave me the best advice on this, and it is that when it comes to Robots especially, $$$ equal cleaning power. I also imagine that cheaper ones are much more prone to breakage.
    I think Robotic cleaners are the future even after having one a short time. I cannot imagine that there is a better technology available to the pool owner in terms of cleaners at this time. I have a very dusty windy environment where I live and this thing has been a life saver. I doubt seriously there will be many times where I actually vacuum the pool.
    Essential Links:
    Pysiek's Avatar
    Apr 2012
    419
    Quote Originally Posted by frustratedpoolmom View Post
    I have one right now. And either I do something wrong or it just don't work. I connect it and place it in the pool and it won't move.
    Quote Originally Posted by Brushpup View Post
    I understand. But I thought something with wheels will be better
    11,969
    You need to close the main drains and just draw from the skimmer. You will hear a "clicking" noise and see it start to move. Make sure it's flat on the bottom.
    Last edited by frustratedpoolmom; 05-24-2014 at 07:53 AM. Reason: spelling again lol
    Pysiek's Avatar
    Apr 2012
    419
    This is what I have right now: Stingray Swimming Pool Cleaner
    11,969
    I agree the cheap robots are the ones that break. As they say, you get what you pay for...lol
    Pysiek's Avatar
    Apr 2012
    419
    I did what you said and it is clicking but it just won't move.
    11,969
    Try bumping the filter? Maybe not enough suction, whats your pressure at?
    Pysiek's Avatar
    Apr 2012
    419
    Suction is strong cause I lift it and put my hand next to the hole and it sucks good. When filter runs normal the pressure is at 16 PSI but I never checked when the cleaner is connected. Give me few minutes and I will check it out
    Pysiek's Avatar
    Apr 2012
    419
    Pressure drops to 8 PSI when I connect the cleaner
    Pysiek's Avatar
    Apr 2012
    419
    Pool cleaner budget around $300
    Can you guys recommend pool cleaner to me? My budget is around $300.
    Thank You
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,412
    Re: Pool cleaner budget around $300
    Please keep all your posts on this topic to one thread. Thank you, Zea3
    Let's narrow this down a bit. Are you looking for a robot or a pump dependent cleaner? What type of debris do you have? Dirt? Leaves? Pine needles? Acorns? Crepe Myrtle blooms? How much debris do you have? What kind of steps do you have?
    Last edited by zea3; 05-24-2014 at 09:07 AM. Reason: merged threads with identical topics
    Love TFP? Become a
    TFP Supporter!
    Pysiek's Avatar
    Apr 2012
    419
    Okay. No trees around so no leaves. Do have some dirt in from installation. I build a deck so we do not step from ground to the pool. Hopefully this will keep it clean. "Robot or pump dependent cleaner" - what do you recommend? I have these steps:
    Jul 2009
    Houston, Texas
    9,412
    Kreepy Krauly type cleaners are good for your situation. If it won't move it either is not getting enough suction or there is a problem with the diaphragm. Has it ever worked for you? If so you may be able to replace the diaphragm.
    I have a pool rover jr and it is great for picking up leaves and acorns, but it tends to stir up dirt more than vacuum it up.
    Love TFP? Become a
    TFP Supporter!
    Pysiek's Avatar
    Apr 2012
    419
    I was looking at pool rover jr but it seems like it "sits" high and won't pick up any sand or dirt. Which Kreepy Krauly cleaner do you recommend?
    Pysiek's Avatar
    Apr 2012
    419
    OMG that thing is stuck all the time!!! Maybe I set up something wrong.... I have weights that came with it . Where on the hose I should place them?
    Guys I read some threads on here and it looks like a lot of people recommend to use wanda the whale.
    Jul 2009
    Houston, Texas
    9,412
    A wanda the whale would work, so would a ranger .
    Love TFP? Become a
    TFP Supporter!
    Apr 2010
    Central NJ
    227
    I bought a zodiac barracuda mx8 a couple of years ago, and I love it. I leave it running for about 3 hours and it does 90% of the pool, I go and vacuum the other 10. As for steps, it won't do them, so I brush them before I put the robot in. I have an IG, I don't know if it will work on an AG, I don't know if that matters.
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
  20. Back To Top    #20
    Pysiek's Avatar
    Apr 2012
    419
    Quote Originally Posted by jrguzmanr View Post
    Looks good but little bit over my budget. I see that MX6 is about $280 but have only one cleaning port.
