Page 1 of 2 12 LastLast
Results 1 to 20 of 39
Thread: Hello good people of the forum (please help!) lol ;-)
    May 2014
    Nevada, TX
    238
    I am sure you have heard stories like mine a million times...but, I was looking for an inexpensive-ish pool for the summer (and hopefully years to come) and turned to CL to start my hunt. I did ultimately find what I thought was a great deal on a pool that needed a liner. It was an older pool...with some light surface rust on the outside of the pool wall but over all with an exception of a couple things the pool appeared to be in really good shape. So, we loaded everything up and got it home and started the fun of getting ready to set up the pool. We are running into a couple of issues and seeing that we have never set up one of these pools before...we are just kind of the blind leading the blind over here so I was grateful to find this community online!
    The pool was listed as a "Doughboy-Type" pool...and it is (or is supposed to be) 12x24x52.
    it is a buttress-free pool. The first issue we are having is the straps seem to have slack in them if we measure the walls out to 12'...AND....as we start to get the bottom track loosely laid out....it is measuring more like 12.5'?!?!?!
    Trying to locate any info on how the bottom track is supposed to go (ie, the railings are different sizes) AND...if we pull the straps tight, then the pool will be slightly wider then 12FT....but the guy swears he bought it used as a 12x24x52 and replaced the liner as a 12x24 replacement.
    I have already purchased the liner via ebay as a 12x24 but I am freaking out over the seemingly .5 foot difference!
    I cant find anything on the pool to tell me who makes it. The only thing I have found (ironically) is an old thread on this board from someone with the same pool wall pattern also seeking the manufacture info to get instructions/help with the pool.
    Here is the old thread:
    http://www.troublefreepool.com/threads/14811-pool-brand
    and here are pictures of MY pool wall (also showing the same stamped VP 99 as mentioned and shown in the previous thread by another user.
    I was hoping that after the time that has passed since the last thread, someone may have some more info and can point me in a positive direction.
    Thank you,
    Steve
    May 2014
    Nevada, TX
    238
    Re: Hello good people of the forum (please help!) lol ;-)
    It seems impossible to NOT be able to find out SOMETHING about this pool. I am going to pull what little hair I have left out of my head over this! lol
    We are really perplexed about the install. The bottom track has 3 different size pieces to it, and we have no idea what size goes where. The way we have it now (just a mock trial) has the posts misaligned from one another. I REALLY need to get some info on this pool. Any help would be greatly appreciated.
    Thanks again,
    Steve
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Welcome to TFP!
    I'm sorry I can't help you with your problem directly, but an idea occurs that we could possibly be able to figure at least part of it out.
    I am assuming a rectangular pool, not oval.
    You say there are several different sizes of bottom track? How many of each size? i would think that the corners should have 8 pieces of a larger size, that could be connected at 90* to each other. the sidewalls would probably be the next largest size, and the endwalls the smallest.
    I doubt that the actual measurements would be exactly 12 x 24.
    Other than that, I'm not sure I can help any further.
    May 2014
    Nevada, TX
    238
    Hey Charlie!
    Thanks for the kind reply. The pool is oval @ 12x24x52
    4 of the smallest peices
    4 of the middle sized peices
    8 of the bigger peices
    Casey's Avatar
    SW PA
    10,452
    Steve, Welcome to TFP. I am not well versed on Oval Pools but I can tell you that youtube may help you figure out the 3 lengths of the track. I know they come with 3 different pieces but as you can see from my sig... I have a round pool because those ovals are very tricky and a lot of work in my opinion.
    Drag.az's Avatar
    Apr 2013
    Amarillo, Tx
    40
    We just put our oval up last year,without instruction's it would have been a hugh failure. TFP has some of the most KNOWLEDGEABLE people in this area. I suggest some pic's of these parts and someone will be along shortly, I dont have a doughboy or I would scan and post, and welcome to TFP...
    13k - Martinique 15x30 52"
    Sta-Rite crystal flo 22" sand filter & 1.5 spl rated
    Gorilla pad / waveless wall foam / foam cove
    Buried 2ft TF-100, TFPC
    May 2014
    Nevada, TX
    238
    Casey! Thanks for the reply! Now someone tells me! lol
    Actualy though, I feel like (IF we can get this up and running) I got a really good deal on the pool. I paid 200.00 for the pool with pump/skimmer/filters and extra supplies... and 250.00 for a liner. About 80.00 for 6 yards of sand and some free labor to get it done (other then throwing some burgers on the grill and some cold drinks). I am sure together....(the good ppl of this online community) me, and google....we can figure something out! lol
    Any help/info is greatly appreciated!
    Steve
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    My oval Doughboy has different sizes of bottom track. If it is a Doughboy you can request a copy of the installation instructions be sent from the company ( no charge) they go waaaay back. My guess however, is that it is some other brand. What do the pressure plates look like?
    ...also, if you could post a pic of the top rail I bet it could be identified
    12 x 28 Doughboy Dinosaur (j/k: Breckenridge) partial bury, continuous depth 9,000gal. Doughboy Power Pak I digital 1hp pump, Hayward Pro-Series 300lb sand filter. Foam panel base, Gladon wall foam, Gladon cove.
    May 2014
    Nevada, TX
    238
    OK! Progress! So today, I started digging around a box that came with the pool and I found these round caps that go in the post caps (sorry I may be calling these things completely wrong names for lack of knowing any better! LOL) on the pool. They clearly have VOGUE on them, so we infact do have a VOGUE pool it would certianly seem!
    That is a start! Anyway, I took a few pictures. One of the pressure plates(?) had something stamped on the bottem. A parts number perhaps? it was the only one that had this stamp so I took a pic and am posting it. I am also posting a pic of the top rail, 3 sized bottom track peices and the support/leg cap. Maybe this will get me closer to finding out what pool I actualy have! LOL
    Thanks again for he help!
    ok this is going to make me makea new post for each picture it seems. here goes.....
    this is the pressure plate that is clearly stamped 21120 or 2/120 ?!?!?
    May 2014
    Nevada, TX
    238
    interesting. it will not let me upload any more images. brb while I figure out how to dropbox and link.
    May 2014
    Nevada, TX
    238
    Ok...lets see if this works! This is the "smoking gun" if you will. it is the VOGUE stamped round piece I found in the box that snaps in the top caps (it appears).
    here is the top rail:
    this is the post caps:
    http://www.euphonicproductions.com/pool/top_cap01.jpg
    here are pics of the bottem track (3 different length/sizes)
    hopefuly this will be helpful in figuring out what pool I actualy have so I can get some intall instructions on it!
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    Yeah! I bet you can contact the manufacturer for installation instruction. ...and pressure plates are actually ( usually) rectangular sheets that lay under the pool. The weight of the water presses down on them and as they are bolted to and rest on top of the buttresses ( buttress-less still has a buttress it is just less noticeable) they support the long sides of the oval. . Brace yourself, this is a major project!
    May 2014
    Nevada, TX
    238
    Quote Originally Posted by Pigeonlove View Post
    I am thinking getting the instructions is a major project! LOL
    So, I emailed and have called Wibar and they have directed me to Trendium Pool Products Inc and I have set an email with requeste photo for them to helpme identify the pool.
    This is certianly slowing down the process! lol
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Are any of the bottom rail pieces actually straight? The pic you posted appears that they all are curved to some extent.
    See if you can separate out of them any that have about a 6' radius to the curve. I would suspect that you will find the 8 bigger pieces will be the endwalls, and the 4 medium and 4 short are supposed to be straight. Or it could be just the opposite.
    We'll help you get this thing on track (pun intended)!
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    Nelson Mandela said; "It's always impossible until it's done." or something to that effect. I actually felt confident UNTIL I received my instructions, then I wanted to cry. But it's done.
    May 2014
    Nevada, TX
    238
    Quote Originally Posted by Charlie_R View Post
    Brilliant! LOL "...or it could be jut the opposite." <---that make me feel so reassured! lol
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    Actually all the bottom pieces are supposed to be curved and usually to the same degree. So I vote, " just the opposite". How many cantilevers are there, six or eight? So all the track between cantilevers should be equal, then probably the longest coming off each end cantilever and then a couple short at each end of the oval. Oval pools have this girdle look to them in the middle, the top rail disguises it in the end.
    May 2014
    Nevada, TX
    238
    You will have to forgive me....
    what exactly is a "cantilever"? if you can explain that to me...I will go count them!
    johnnysnok's Avatar
    Feb 2011
    South Jersey
    192
    I have a Dough Boy 12'x 24' Oval and if you can see it in these photos?
    The side walls to curve in and out between the upright supports. This may be the reason you are seeing the curved rails in your case.
    Unfortunately i do not have any photos from the install to share which may give you a better idea of the curves.
    Hope this helps you in some way?
    Dough Boy 12' x 24' Oval
    Wedding Cake Steps
    1500 SF Timber Tech Composite Decking
    Video of my pool and retaining wall....Above Ground Pool Ideas - YouTube
  20. Back To Top    #20
    May 2014
    Nevada, TX
    238
    stunning pool! Thanks for sharing the photos!
