Thread: Adding water for the first time.
    Sep 2013
    Nashville, TN
    382
    Hopefully the liner will be installed this weekend and we can start adding water. We are filling off the house/ city water so it shouldn't have any crazy issues. I did a simple test on the tap water to see where it was at and how to use the TF-100 kit. What should I be looking for to get started? We have a SWG but think I will start with bleach to get it dialed on first, does this sound right?
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Adding water for the first time.
    Sounds perfect!
    You know you'll need bleach and CYA. You might need baking soda, or borax, or acid. The test will have given you a hint. Once it's circulating, test again, and start balancing. Once it's going well, raise CYA, add salt, and fire off the SWG.
    Check "Diamond Day" Post 5
