Thread: Pool remodel having PCC 2000 cleaning system. Need to replace the drain cover, but...
    Oct 2013
    Phoenix area
    91
    My pool is plastered and ready for water today but not confident in the PB replacement drain cover. Maybe I am overthinking this but the all the drains he wants to put on don't appear debris will fit through the slots. I dotn want to be brushing and skimming debris off my new updated pool bottom.
    The existing cover was flat on top and was raised about 1/2" off the pool bottom. The covers I am being presented are vented.
    Don't have any pics to show but hoping someone will know of a drain or part # so I get the right drain cover?
    thanks in advance!
    chris
    13,000 gallon IG
    PCC IG cleaning system
    Pentair equip.
    Attached spa
    Dire need for surface refinish!
    Re: Pool remodel having PCC 2000 cleaning system. Need to replace the drain cover, bu
    you definitely need to get the proper drain cover - your existing drain is designed for sucking in debris.
    28000 gallon IG pool, 3.5ft - 8ft deep, Stonescapes Tropics Blue Interior, Pentair Intellichlor SWG, Pentair Quad DE 100 filter, Pentair Intelliflo VS-SVRS, Whisperflo 3hp (water features), A&A Max in floor cleaning, Pentair Easytouch 8 Automation, Screenlogic II, Pentair Mastertemp 400k BTU heater, Pentair Intellichem with acid injection via stennar pump, 9'x7' spa with Infiniti edge
